Author Topic: 1978 CB750 - Re-born a 836cc Wiseco JMR Ported Hot Rod  (Read 38604 times)
Offline BLAC
  • An espresso is a
Re: 1978 CB750 - Re-born a 836cc Wiseco JMR Ported Hot Rod
« Reply #175 on: March 02, 2017, 09:10:39 AM »
... i mean woooooo. 👍
Sent from my SAMSUNG-SM-G935A using Tapatalk
He's a CB ridin', engine case shinin son of a gun!
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline Ericcb750
« Reply #176 on: March 03, 2017, 11:38:10 AM »
Hey Fellas, Glad you like it...Going to look sweet with the new brass in there...
Ruckus, One never reveals his sources....... EXCEPT TO SOHC FORUM MEMBERS... ha-ha. If you need carb internals (which they rarely wear out, but with all the work i put into these i figured what the heck)... You can get them on Yamiya (straight outta japan)..... Also, some local places will have them, some of the Honda parts houses (or JT Marks on Ebay has a heavenly amount of NOS honda stuff).
I've heard/read that the K&L kits are supposed to be pretty good also....THey're made in Japan as well (supposedly closest to OEM ??) But i've never used them first hand, I usually just use the soft parts from those type of kits (had issues with Keyster jets in the past).
Nils, is the man, I'll post up some new photos shortly guys.
Also, Anyone familiar with using a "thread clean-up kit" or something on the stud holes? Mine are perfectly clean and none are stripped but NIls recommended it..... I have 8 x 1.25 taps but wasn't sure if it's something different? Want to make sure everything goes together well, BrandEn's top end re-build thread is pretty good.
Thanks guys.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Online MRieck
« Reply #177 on: March 04, 2017, 06:55:05 AM »
« Reply #178 on: March 04, 2017, 11:13:35 AM »
I bought this set of metric 'thread-chaser's from MSTC up in Wakefield, MA. a couple yrs. ago and they are very reasonable for the set.They go from 6mm-12mm;the good thing w/ them is they don't remove any metal or cut(over-cut  :o) new threads,just clean the dirt out of the threads and straighten damaged threads out to make them useful.
« Last Edit: March 04, 2017, 11:21:26 AM by grcamna2 »
Online MRieck
Offline Ericcb750
« Reply #180 on: March 29, 2017, 11:47:15 AM »
Hey Guys, hope everyone is doing well. I've been slacking big time on the build thread getting the bikes ready for the season. However I received a second pack of skittles and another box from Phoenix the other day.... and Nils does it again... these puppies are going on the bike for sure!!!
Aluminum bodied KONI 7610 "D" Special 's fresh from a complete rebuild and overhaul.... a bit of vapor blasting has these shocks looking better than new!!!
Will post some more updates shortly. Appreciate all the support.
1978 CB750K
2005 Sportster 1208
Offline BLAC
  • An espresso is a
« Reply #181 on: March 29, 2017, 02:50:33 PM »
Beauties!
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #182 on: March 29, 2017, 10:53:46 PM »
Very nice process! Those parts are so amazingly fresh. I can't wait to see it all together. It's going to be one mean ass cb750.
« Last Edit: March 30, 2017, 07:47:46 AM by JoeCooley »
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Ericcb750
« Reply #183 on: March 30, 2017, 07:15:56 AM »
Hey Blac and Joe, THanks fellas.... Yeah the shocks came out amazing.... couldn't be happier and Nils is a super awesome guy.
Joe as far as the motor, I highlighted all the upgrades/mods at the beginning of the thread but it's going to be a Wiseco 836cc for the bore, Head was completely re-done by Mike Rieck (JMR Porting) , stage 2+ porting with Oversize intake valves (new exhaust valves also), HD APE Springs, New early style keepers (69-76 style), Cast iron Guides, the whole schebang.... Webcam 63A, Cycle X super rods on a balanced crank with all new rod and main bearings....HD Primary and Cam chains with new tensioners, APE Clutch pack, APE Cylinder studs and also APE HD Main bearing studs..... It's basically going to be a very hopped up brand new motor...... let me know if you have any questions..
I checked out your build also, looking solid man!!! These bikes are so much fun, i absolutely love my stock 78K but man this is going to be a BEAST!!!!
1978 CB750K
2005 Sportster 1208
Offline JoeCooley
« Reply #184 on: March 30, 2017, 07:57:01 AM »
Thanks for the clarification and the good words. I must've confused you're thread with the JMR Billet block thread. You have a very solid build. That 836 is going to scream!
These bikes are a blast. It's surprising how much fun you can have on an almost 40 year old cb. At least 50 smiles per gallon... 😎
Offline Ruckus2115
« Reply #185 on: April 05, 2017, 07:53:52 AM »
Do you have any plans to have the stator rewound? I assume you have all new electrical parts coming in and just haven't gotten to that part of the build yet. I also do not know what sort of power it out put you want. Just kind of curious with your alternator/stator plans as you put this all back together.
« Reply #186 on: April 05, 2017, 09:32:15 AM »
Ruckus2115,
Why would he need to consider having the stator rewound?  This is a part that VERY RARELY has issues.  Charging is anemic on CBSOHC4s compared to modern bikes, but the stator is NOT a common source of failure.  The usual culprit of a defective charging system is a short in the 40-year-old wiring.
Here. Eric has no plans to run EFI or taxing electronic accessories that I am aware of, so the stock charging system should suffice.  IF he wanted to augment the charging system, he could go with an Anders-build 32 AMP upgrade, but that is overkill for his needs.
Offline Ruckus2115
« Reply #187 on: April 05, 2017, 11:27:26 AM »
I was really just curious if he had any plans for that area of the rebuild. Wasn't suggesting that he needs to. And from my research I have gathered that yes these are pretty bullet proof stators. Was really just wondering what else he planned to do with the rebuild. Wasn't a loaded question or anything. Genuine curiosity that's it.
Offline Ericcb750
« Reply #188 on: April 05, 2017, 11:43:27 AM »
Thanks for the info on the stator...So Far I have already picked up the wiring for an entirely new harness... i have an M-unit v.2 as the brain, new Ricks Reg/rec, Dyna Coils, dyna ignition, All New Moto-gadget 3 button momentary switches, New H4 headlight, LED tail light , and 4 spankin new Moto-gadget pin turn signals,  Also, My buddy Don helped me out by selling me a KOSO speedo/tach combo that i have mounted up to the front end in my garage at the moment...
I had Devin (at Cognito) drill and tap a couple bolt holes into the lower side of the top triple so I could mount a few different types of gauges.....
I may have bitten off more than I can chew with this as I've never wired a bike but I will take my time and have help from the pro's when needed.....I also picked up a full motogadget wiring kit to go along with it.
I've never put this much into a bike before ($ or time) so it is definitely initimidating but i know in the end it's going to be the EXACT BIKE That i wanted...... Always appreciate info/advice and a lot of the guys here have been awesome...
Don has been amazing, Cal helped me out with some wiring diagrams for literally the exact wiring job i'm doing....
1978 CB750K
2005 Sportster 1208
« Reply #189 on: April 05, 2017, 12:12:19 PM »
Ruckus,
Hey. I wasn't trying to bite your head off or anything.  I had a charging issue on my first 750 and (and a proclaimed 750 guru) had me change the stator.  A few bucks later (on ebay) and lots of time lost, I still had the problem with a newer stator.  It turned out to be a short in the harness.  From years of other similar stories, it is almost always the wiring.  I've never heard of the stator crapping out, other than with severe crash/rash going through the side cover and into the stator.
The long and short of it is to check the charging system and make sure it is functioning within spec.  With a from scratch wiring harness, reproduction, or the old one, if there's a charging issue, FIRST check the wiring connections before re-wiring or replacing a stator.  Or, if you are going to convert to EFI, you will definitely need a charging system upgrade.
« Reply #190 on: April 08, 2017, 11:35:27 PM »
 I finally rode the K2 I bought with the K1 Wiseco? big bore engine, this thing is a beast. W0W!. I'd love to slap on a ported head and cam.
Offline Ericcb750
« Reply #191 on: April 13, 2017, 12:31:28 AM »
Hey Don R, That's awesome to hear!! I've only ever rode a stock 18K mile 78 cb750 and even that thing boogies pretty well!! so I am very excited to ride a real fresh hopped up version with the ported 836... this thing is going to scream and hopefully be pretty reliable.
1978 CB750K
2005 Sportster 1208
« Reply #192 on: April 13, 2017, 08:31:57 AM »
My K8 with a Wiseco 836, ported head and cam was no joke.
« Reply #193 on: April 13, 2017, 09:58:17 AM »
A CB750 like your project is a good and reliable touring machine!  Strong power that handles 2 persons with luggage bags and more really well. My bike had no problems twisting the throttle at around 150kmh to pass cars on Autobahn as well as highways in Italy, France and Spain. Cruise most of the day in 150-180kmh, sometimes even more.
Cam I used back in the touring days, meas when I timed it:  IN 257* 22/55, EX 260* 56/24 @0.04"lift   Lift@0 lash: 0.361"/0.361" (9.18mm)
Timing differed a  degree or 2 when I timed it several times. I looked for equal LC. Duration could be 2-3 * less too when tighten 0 lash better or use of tighter cam holders with rocker shafts.
You guys living in USA have a huge area to go by bike!
Online MRieck
« Reply #194 on: April 13, 2017, 04:07:31 PM »
You ride up here Eric and I'll take 1000cc CB out. You can try it too. ;)
Offline BLAC
  • An espresso is a
« Reply #195 on: April 13, 2017, 04:10:15 PM »
Ride up there, Eric!   ;D
Offline Ruckus2115
« Reply #196 on: May 12, 2017, 05:49:28 AM »
How's the build going? I am doing a similar 836 kit and was wondering if you have installed the Super Rods? What's your opinion on those?
I'm trying to see if I should spring for new rods or get my stock rods polished and balanced..
Offline Ericcb750
« Reply #197 on: July 19, 2017, 11:18:22 AM »
Hey Fellas, hope everyone is doing well. I have been slacking real bad on the build...been trying to get in as much riding as possible.
Ruckus2115, The Super Rods are EXTREMELY well made pieces...I was looking at having the stock rods shot peened/polished but the small ends had a little bit of galling on them so i ended up saying "F" it and doing the Super Rods, they're absolutely beautiful, have nice heavy duty bolts and nuts and brass bushings in the small end. I ended up getting brand new bearing shells for the rods and the crank so this motor is litreally going to be a brand new Monster version of what honda produced back in 78.
I'll get back on the band wagon with updates and the build , now that all my cases and everything were vapor blasted by Nils (THE MAN by the way) , i'm ready to rock and roll.
I'll get crankin and post up my progress, first is to get that stubborn kick start back in and new bearings on the mainshaft and countershaft..... Thanks for all the support
1978 CB750K
2005 Sportster 1208
Offline Ericcb750
« Reply #198 on: October 30, 2017, 08:32:52 AM »
Can't believe how the time has flown...This build is getting done this winter. I'll post up the step by step, gotta dig into a huge box full of Freshly vapor blasted parts from Nils and start building!!! I know it's been a while, will get this thread going again.
1978 CB750K
2005 Sportster 1208
« Reply #199 on: October 30, 2017, 10:14:02 AM »
Repairing, modifying a CB750 is a never ending story :-) You might change your mind about the build and change some with help of all other builds going on here!!
I have a K6 that need some repairs (leaking fork due to scratched tube).
I started a K2 build since I had a K2 case I could fill with leftover parts from my K6 and knew a K2 frame with registration i could buy. This will be a close stock with no engine mods.
What to do with my 836 cylinder, 900cc cylinder + old ported head with std valves + some cams + K6 transmission, clutch,  VM29 carbs I have? + 2 extra tank sets.
I need to find 2 cheap engines I can use...... This is a very addictive hobby thanks to this forum and all helpful resources with many years of experiences.
