Original rotors are sintered material... they are very soft. You are very close
This is steel 4150... I will probably leave it like this... without further thermic treatment. Because it is already harder then original rotors. Or maybe I will do slight nitrating to around 55RC.
The reason I am doing this is because I cant put old worn rotors. I know they will works but it is a risk. This rotors I am making will outlast old ones by big margin
And I made my own springs for oil pump
I adjusted spring lengths so pump will give me a little bit higher pressure.
I am asking for interest because machinist shop will charge according to ordered quantity... The bigger the order it will be cheaper per unit... And it will be below 200$ for sure.
