SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
quick oil change question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: quick oil change question (Read 824 times)
andy8190
Expert
on:
July 31, 2016, 05:55:10 AM »
I have a cb350f and I put new oil in it yesterday and suspect the new o ring on the bolt is leaking. Can I remove the filter cover without draining the oil pan?
Logged
DaveBarbier
Really Old Timer ...
Re: quick oil change question
Reply #1 on:
July 31, 2016, 06:31:39 AM »
Some oil will definitely spill out. Less if you have the bike off the main stand. And even more less if you have the front raised. You'll have to replenish the oil the drains out, but no need to drain the oil pan.
Logged
Patina Hyena - 550/650 674cc Hybrid Cafe Build
The Mayor - ‘79 CB650 Factory Revive
Need a full oil pump o-ring kit for your 650?
Want to use a Dyna S ignition on your 650?
andy8190
Expert
Reply #2 on:
July 31, 2016, 06:43:34 AM »
thanks very much. I will def tilt the bike back.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
