SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
cracked lower case
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: cracked lower case (Read 727 times)
maddog63
Full Member
cracked lower case
on:
July 23, 2016, 07:42:40 AM »
I have a 75 400f. I was tighting the lower motor mount bolts and I cracked the case right on the oil gallery just below the oil filter. I am a welder so I'm going to try and weld it. Has anybody else done this? What is the proper way to bolt the engine in? Does it matter which bolts you tighten first?
Logged
DaveBarbier
Really Old Timer ...
Re: cracked lower case
Reply #1 on:
July 24, 2016, 11:16:33 AM »
Shouldn't matter which bolts are tightened first. Upload a picture so we can see the damage. It could probably be TIG welded. I've heard of people welding the cases from chain damage and collisions. All it takes is a competent welder and cleanliness.
Logged
Patina Hyena - 550/650 674cc Hybrid Cafe Build
The Mayor - ‘79 CB650 Factory Revive
Need a full oil pump o-ring kit for your 650?
Want to use a Dyna S ignition on your 650?
maddog63
Full Member
Reply #2 on:
July 25, 2016, 12:20:32 PM »
will do thanks.
Logged
scottly
Global Moderator
Humboldt, AZ
Reply #3 on:
July 25, 2016, 01:45:35 PM »
Please post pictures of the cracked case, with the motor still in the frame. Tightening the mounting bolts shouldn't have damaged the case, unless something was incorrectly assembled.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
cracked lower case
