Author Topic: carb rebuild and now choke plates sticking/hard to open  (Read 1367 times)
Offline yitzac1990
« on: July 25, 2016, 07:35:48 PM »
Hello, I just rebuilt the carbs on my 1978 CB750K, got them all together (minus the slow jets, still waiting on those), and now the choke linkage/plates are sticking.  when I pull up on the choke linkage (as the cable would do when installed), the plates basically dont move, or move very slowly and very little.  any idea why this is happening?  Can anyone point me to some close up, detailed pictures of how the carbs assemble together in their "rack", specifically where the 2 choke linkages meet?  I tried searching, but couldn't find anything too detailed in that area, nor in the technical service manuals.
Thanks
1978 CB750K
Offline b52bombardier1
Re: carb rebuild and now choke plates sticking/hard to open
« Reply #1 on: July 26, 2016, 04:38:53 AM »
Spray some oil on the choke shafts and work it. Mine did the same thing but are good now.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline yitzac1990
« Reply #2 on: July 26, 2016, 05:09:06 AM »
Ok ill give that a try later today.  Is it safe to say that over time they will "loosen up" as I run the carbs on the bike?
1978 CB750K
« Reply #3 on: July 26, 2016, 09:21:35 AM »
If you removed the choke plates during your rebuild, its possible they are shifted slightly and hanging on the carb throat walls.
To fix this, partially loosen the 8 choke plate screws so they can 'self-adjust' within the throat of the carb.  Lift the choke so the plates close, center the plates, and then gently tighten the screws.
There should be no contact between the plate edges and the cab throat walls.
Offline machacc
« Reply #4 on: July 26, 2016, 04:26:18 PM »
Mine were stiff after sitting for years also.  I had to spray lube them twice but they did loosen up and do work right now.  Ron
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: July 26, 2016, 04:31:32 PM »
+1
There is no direct connection between the choke linkage and the choke plate shafts. The shafts that the choke plates mount to are spring driven and are very sensitive to any drag and/or misalignment. flybox1 has described a good corrective action.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline yitzac1990
« Reply #6 on: July 28, 2016, 09:29:37 PM »
got it guys.  i loosened up the 2 center plates and they instantly became free to move.  snugged the center plates back up and were good.  thanks all!!
1978 CB750K
« Reply #7 on: July 29, 2016, 03:43:07 AM »
Thanks for posting your resolution.  8)  Too many resolve their issue and never come back.  :(
TAMTF...
Wilbur
Projects:
« Reply #8 on: July 29, 2016, 06:32:11 AM »
Glad it was an easy fix!  ;D
Offline yitzac1990
« Reply #9 on: July 29, 2016, 11:18:28 AM »
no problem, I know how it is....searching forums and someone has the same question, but no posted resolution!
on a side note, my work computer proxy blocks this forum and i cant do anything on here until I get home... so sad!
1978 CB750K
