Quote from: bwaller on July 27, 2016, 07:30:43 AMweighing the stockers would add persepctive. Sheesh, now you are getting picky..... . I'll weight a set of steel stock retainers when I get home today to compare.George
Quote from: MRieck on July 31, 2016, 05:57:41 PMQuote from: scottly on July 31, 2016, 05:31:20 PMWhut's a Rimac? Valve spring tester? Yes sir. And they are now out of business. WE have two of them.
If you ever tried to cut Titanium with a hack saw you will know the difference
Quote from: gschuld on July 27, 2016, 09:31:18 AMQuote from: bwaller on July 27, 2016, 07:30:43 AMweighing the stockers would add persepctive. Sheesh, now you are getting picky..... . I'll weight a set of steel stock retainers when I get home today to compare.GeorgeStill waiting to hear what the weight of the stock retainers are. OK, you got me. I found that I actually did not have any factory stock steel retainers handy like I thought. So out of pure guilt, and curiosity, I grabbed one of my crusty parts motor heads and pulled the 4 intake springs retainers and keepers.
Take one apart.....something out of Bedrock in terms of mechanical sophistication.
Somehow my mind would allows lean towards those retainers breaking due to the holes.
Quote from: dragracer on August 03, 2016, 08:46:39 PMSomehow my mind would allows lean towards those retainers breaking due to the holes. I think they stopped making them. Hmmm.
I have a set of red retainers on an old head and read up on them, I assumed they are aluminum.
Quote from: Don R on October 01, 2025, 05:17:35 PM I have a set of red retainers on an old head and read up on them, I assumed they are aluminum. Yes sir....more than likely RC parts.
BTW.....I'd never use aluminum for anything unless it was being rebuilt on a schedule.
I read the way to tell is touch it to a grinding wheel, if it makes sparks its Titanium. Buuuut can I do that without ruining it?
Same guy had a few "rev kits" too...nobody actually USED a rev kit.
Quote from: willbird on October 03, 2025, 07:12:25 AMSame guy had a few "rev kits" too...nobody actually USED a rev kit.What is a "rev kit"?
Quote from: Don R on October 03, 2025, 08:53:59 PM I read the way to tell is touch it to a grinding wheel, if it makes sparks its Titanium. Buuuut can I do that without ruining it? Weigh it Don.
A "rev kit" was another set of springs in the lifter valley, I believe it helped keep the valvetrain from floating the valves. Maybe, by keeping the lifters seated on the cam.
