Author Topic: 74 CB750 Pilot Circuit Question  (Read 772 times)
Offline Wingnut74
« on: July 27, 2016, 01:42:50 PM »
 I have been unable to chase down the source of new sooty richness on carbs 2 & 3 that popped up after a cleaning with Gumout, compressed air, and running the smallest two wires in one of those carb cleaning tools down the passage from the intake to the main jets.  I confirmed good flow when I shot Gumout into the idle mixture screw hole and it shot out the pilot jet.  None of my idle mixture screws have ever really done anything more than barely noticeable. Plugs were perfect before this cleaning and Carbs 1 & 4 still are. I am now thinking maybe whatever is the air intake source for the pilot circuit is plugged (or is the idle mixture hole the source so that theory is wrong?). What is the source of the air that is metered by the idle mixture screw? Does any if this sound right? Read a lot of posts but am stumped. thanks
74 CB360 - Winter 2014/2015 Project
74 CB750 - Winter 2015/2016 Project
70 Something TBD - Winter 2016/2017 Project
Re: 74 CB750 Pilot Circuit Question
« Reply #1 on: July 27, 2016, 01:46:19 PM »
what exhaust setup are you running?
intake config?
Jet sizes?
Need more details to be able to assist.
Offline Wingnut74
« Reply #2 on: July 28, 2016, 08:07:39 AM »
Stock airbox, 105 and 40, cyclex 4into1 sidewinders. Plug color was perfect on all four until my "cleaning" made just 2 & 3 rich. So jets I think r fine size - maybe something got plugged? I saw somewhere that there are four openings in that circuit. I have only confirmed two are clear. jet and air screw
