Author Topic: 74 cb550, electrical issue suspect bad coil.  (Read 1134 times)
Offline stolle
    • stlhondas
« on: July 30, 2016, 11:48:59 AM »
Awhile back I was cruising down the highway and the bike started to feel like it was running out of gas so I switched to reserve and no change limped it home. It was running on two cylinders 1 and 4, 2 and 3 were not firing. I found that the 2/3 points were arcing like crazy, replaced the condenser and the arcing stop and the bike ran normally again. Last night I go to start it and the neutral and oil lights dim like the battery is dead bike won't start (kick only it has no starter motor) ran before this but started sputtering like it was before when the condenser went bad, not near as bad though. I call a friend to pick me and the bike up by the time he gets there the bike starts. We still load it in the truck. When I get the bike home I immediately check the condenser, it seems fine. There is a random high amp draw. Sometimes it's there some times its not, I traced it to the 2/3 coil this is the one that had the bad condenser. I checked the coil per the write up on here and it checks out. When it's hooked up is when I have the issue. Is it possible the coil could have a short to ground that's only there when power is applied. I suppose the bad coil could have been the reason my condenser went bad? Anyway any insight is appreciated.
Thanks
Offline stolle
    • stlhondas
Re: 74 cb550, electrical issue suspect bad coil.
« Reply #1 on: July 30, 2016, 12:39:54 PM »
I made the entire harness, I will tell you that it matches the stock harness as far as the ignition goes there is nothing as far accessories just a headlight and a taillight. With the ignition on the only thing that has power is the led taillight and the stock idiot neutral and oil lights. It has ran perfectly fine now for 700 miles. The battery is brand new, I thought that was the problem. I bought one this morning still does the same thing. Plugs and caps are new points and condensers had about 700 miles points gap is fine set at 14 thousandths. Both coils measure the same across primary and secondary there are no shorts to ground I have rang out every circuit on the bike, there aren't many. Everything is clean. I'll do some more testing on the coils and report back.
Offline stolle
    • stlhondas
« Reply #2 on: July 30, 2016, 02:18:33 PM »
I should just asked if coils short to ground and if a bad coil would kill a condenser. I don't remember ever reading anything about testing coils to ground.
Offline 540nova
« Reply #3 on: July 30, 2016, 02:31:18 PM »
Your coil absolutely can short to ground. Here is something to read...
1974 CB450, 2006 CBR1000RR
