Author Topic: Carb rebuild to jet or not to jet  (Read 971 times)
Offline ceebass68
« on: July 30, 2016, 06:05:39 PM »
So I'm getting into my recent barn find. Pulled the carbs off and started cleaning. Kind of stalled there as I have been reading opinions on what/how to do.
My plan was to buy a rebuild kit with jets and rubber then, I noticed there is a big range in pricing. Kits can be had from $15 each up to $30 each. Wanna do it right but don't want to pay double if it's not necessary. Thoughts?
Also, I have seen a few opinions suggesting to clean what is in there, don't replace. Ok so...here I am in a debate...
The rubber internals seem hard and I'd be surprised if it seals well. Should/could I just replace the rubber?
Thanks for any help. Anxious to get to the next step.
Note that this bike (1975 CB550F) has 16,500 miles but the last 1,000 since 1987. Pretty positive it has sat a long time.
1975 CB550F (long term project)
1976 CB750F (short term project)
1976 CB750A (future project)
2006 VTX1800C (primary rider)
1995 VN800a (son)
2001 VN1500LC (highly modified - for sale)
Lots of others now gone
Offline b52bombardier1
Re: Carb rebuild to jet or not to jet
« Reply #1 on: July 30, 2016, 06:39:14 PM »
You should be able to save your current brass jets and reuse them.  And if you are careful, you might reuse the gaskets.  I try to stick with Keihin rebuild parts, if possible regardless of cost.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: July 30, 2016, 06:50:43 PM »
Replace the rubber, keep the brass, with the only exception being the float needles and seats (these items truly wear and are maintenance items). Either use genuine Honda parts, or if you must go aftermarket, at least verify that the rubber is Viton. I used non-Viton rubber carb bits that turned to goo within a week upon exposure to 10% ethanol laced fuel...  :(
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline ceebass68
« Reply #3 on: July 31, 2016, 06:09:54 PM »
Thanks for the opinions guys! I'll try to find some OEM rebuild parts without jets. I saw a cleaning tool with needle small pokers and brushes. May get one of those on order too...
1995 VN800a (son)
