Author Topic: APE Ultra Cranks  (Read 12488 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: APE Ultra Cranks
« Reply #50 on: November 20, 2016, 05:10:38 PM »
"Affordability" on the other hand is a very relative term in "bleeding edge" technology.  ;)
Q: How fast can I go?
A: How much money you got?
 ;D  ;D  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline kmb69
« Reply #51 on: November 20, 2016, 05:14:48 PM »
 ;D  ;D  ;D
 ;D  ;D  ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #52 on: November 20, 2016, 06:13:18 PM »
Yep, bleeding edge technology make yo wallet bleed!
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
« Reply #53 on: November 20, 2016, 09:15:43 PM »
Time to stay in my lane- lol
Offline Big Jay
    • CBRzone
« Reply #54 on: November 20, 2016, 11:04:14 PM »
The Carrillo card you posted is not the 750 sohc. Part number looks like an 1100F dohc. 750 specs are as follows;
    • BentON Racing
« Reply #55 on: November 21, 2016, 04:38:26 AM »
Mine all weighed 316 on my scale.
« Reply #56 on: November 21, 2016, 01:30:29 PM »
One of them broke?
    • BentON Racing
« Reply #57 on: November 21, 2016, 01:49:46 PM »
Yep...but pin went first!
Offline dragracer
  • CB750F Dragbike
« Reply #58 on: November 21, 2016, 04:10:30 PM »
Pin, piston and then rod- in that order I'm certain. Chain, cases and block were collateral damage. Crank is probably a safe bet for use in a street motor at this point- not sure I'd trust it in my 1000cc plus race engine.
    • BentON Racing
« Reply #59 on: November 21, 2016, 06:48:48 PM »
Crank gone too, stripped the teeth for primary chains!
Offline dragracer
  • CB750F Dragbike
« Reply #60 on: November 21, 2016, 06:52:50 PM »
Oh crap. Carnage to the max. So now the only salvageable parts are the head, cam, and transmission?? Is the clutch basket okay??
    • BentON Racing
« Reply #61 on: November 22, 2016, 04:05:23 AM »
Clutch looks fine. .....more pics when I finish splitting cases after work later today!
Offline dragracer
  • CB750F Dragbike
« Reply #62 on: November 22, 2016, 05:23:35 AM »
I think we're stepping all over Big Jays'  original thread. It's turned into a post about your engine. Sorry Jay.
« Reply #63 on: November 22, 2016, 05:56:02 AM »
Although, Bill's motor looks like a good candidate for one of Jay's Ultra Cranks!  ;)
As long as Bill keeps tearing them up without hurting himself, Jay will keep selling him crankshafts.  ;D
Wouldn't mind having one of those Ultra Cranks myself...  :-\
TAMTF...
Wilbur
Projects:
« Reply #64 on: November 22, 2016, 09:29:43 AM »
I think that all posts with APE Ultra crank are good as long as we SOHC:ers order a set or 2 from APE or another tuner, included in a package. Bill will get another APE crank, right?
« Reply #65 on: November 22, 2016, 09:37:04 AM »
The APE Ultra crank is not that expensive if the result is taken to account. Smooth running engine from idle and up. New rubbers in the primary hub and all chains with tensioners replaced. Goodbye old rattling CB750, welcome  better than new! Undercutted gears  too when engine is open. I talk about my bike....
Offline Big Jay
    • CBRzone
« Reply #66 on: November 23, 2016, 08:23:01 PM »
[/quote]
[/quote]  Why don't we have a like button.
« Reply #67 on: November 23, 2016, 11:28:26 PM »
[/quote]
Your not the first one to say that... ;)
« Reply #68 on: November 24, 2016, 12:23:39 AM »
That button might overflow the server ;)
Serieously: A balanced crank + alternator rotor together with mentioned bottom end restore will give more for the bucks than a new sets of carbs that is easy to hang on later when an opportunity knocks on the door.
I should have invested in that instead of Smoothbores back in early 80's. Problems with the cracking carb boots made me to use the std carbs. Same top speed.
More $$$ invested in hp + torque increase, a good idea to protect with better rods.
Edit: I could not stop thinking about it.
Balanced crank as mentioned here should be the start in all CB750 engine restores. Not only HP +rpm guys. An old engine will probably need a refresh of the crank, new rod bearings etc. anyway.
Bottom restore kit to start with:
- APE "Infra" crank, lightened, balanced. polished journals..... with refreshed std rods + F2 bolts
- Balanced and maybe lightened alternator rotor. Or a balanced later model.
- New rubbers in prmary hub. The 2 needle bearings inside are cheap std bearings....
- All 3 chains with tensioners
- Additional undercut of gears
- New ball bearings if engine has many miles. Std should work 100.000kms, right?
When this is done:
- Doing the cylinder. Refresh gasket surface, Pistons: Std over size/ cheap low CR 836/CR 10 something 836 for hotter cams.
- Old fogotten head must get cut seats, milled gasket surface, blasted outside as well as inside. Maybe some guides and valves. Std K last long. My K6 did despite hard life with min warm-up and bad oils. Before it was tuned.
- Optional port job. Minimum remove the burrs, improve the chambers around the valves.
- Cam like 341. Hotter needs new springs and seriously ported head, right?
- Better carbs after MRieck stage 4 head or similar.
« Last Edit: November 24, 2016, 11:19:22 AM by PeWe »
