Author Topic: K2 Broken, then repaired top triple clamp.  (Read 8263 times)
Re: K2 Broken, then repaired top triple clamp.
« Reply #25 on: August 08, 2016, 03:17:41 AM »
To anyone that wants a broken triple clamp (Terry?), they can have mine for the price of shipping, free if you pickup it up in Santa Clara.......just have to take it off the bike one of these days
SOLD! Thanks mate, as much as I'd love to pick it up, I could probably buy a NOS one for the price of travel from Oz to Santa Clara, but more than happy to pay postage, plus I'll kick in enough for a fine (well, cheap, like me.......) bottle of American whisky. Thanks mate! ;D
Offline somesuch
« Reply #26 on: August 10, 2016, 11:06:27 PM »
PM inbound
Offline beemerbum
« Reply #27 on: August 12, 2016, 08:52:23 AM »
So is there a torque value on the bolts so as to not overtighten and crack?
I've never used my torque wrench on it, just tighten by feel.
The triple tops that I've seen broken are typically missing the D-washer, which acts as a spacer.
I've got a couple extra washers and I take one as an example w/ me to the hardware store to match up for the correct thickness and that way I make-up a few spares to keep from cracking that good hard(and brittle cast aluminum)oem original top triple.The other thing to be very careful with is removing the top triple,use plenty of WD40 and whatever you do don't use a steel hammer or drift punch.
Since this thread, I have discovered that the PO of my 1971 K1 750 left out the D washers on the upper bolts. Now I want to assemble it correctly. What is the thickness of the D washer and/or where can i procure them?
Offline beemerbum
« Reply #28 on: August 12, 2016, 01:17:07 PM »
Never mind guys. Hondaman says these washers/spacers on the upper crown bolts are 2mm thick. Also, they are available as genuine Honda parts from David Silver. They are part # 53235-300-000
Offline grcamna2
« Reply #29 on: August 12, 2016, 01:31:00 PM »
When I look online for this part it says NLA
75' CB400F/'bunch o' parts'
Offline 540nova
« Reply #30 on: August 12, 2016, 01:37:03 PM »
That would be so simple to make. Take a standard washer 2mm thick and grind down one side to attain the D shape.
1974 CB450, 2006 CBR1000RR
Offline grcamna2
« Reply #32 on: August 12, 2016, 04:07:32 PM »
I've already made a few previously,I was careful to round the edges so they would have even seating when torqued.
« Reply #34 on: August 12, 2016, 10:17:15 PM »
My K1 triple never had the washers, and never broke, but I was warned early on
not to over-tighten the bolts. ;)
Offline tlbranth
« Reply #35 on: August 13, 2016, 11:37:42 AM »
When I restored my K0, both sides of the top tree were broken. I got a new one on ebay and after fiddling a bit I decided the washer was too thin so I made my own. If you think about it, it's the lower tree that keeps the forks from moving up and down. The top tree just keeps the fork from rocking front-to-back. So I made washers that kept the top tree snug. No more than that. It's still intact after several years.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #36 on: August 13, 2016, 12:13:44 PM »
 The washers under the head nuts on a 750 engine are supposed to be very close to the proper thickness. One side needs to be ground flat and they are slightly larger around.
Offline beemerbum
« Reply #37 on: August 13, 2016, 01:27:51 PM »
Here's the link to DSS and the part....http://www.davidsilverspares.com/parts/by-part-number/partnumber_31842/
Offline tlbranth
« Reply #38 on: August 13, 2016, 03:13:15 PM »
Ten bucks for a washer? Does it come with dancing girls and a free car wash?
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline beemerbum
« Reply #39 on: August 13, 2016, 03:33:34 PM »
Yeah, I know. I guess it gives me warm fuzzies to open a package for a genooine Honda part.
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« Reply #40 on: August 15, 2016, 02:39:51 AM »
Here goes with my CAD drawing to make your own 'D' washer / spacer. Note the 'Checked By' name  in the drawing  :D :D
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline somesuch
« Reply #41 on: August 15, 2016, 02:01:16 PM »
For anyone looking to make their own washers, I measured four sets last night and they were all 2.28 mm.
Offline somesuch
« Reply #42 on: August 15, 2016, 02:02:57 PM »
Offline Old Moe Toe
« Reply #43 on: August 16, 2016, 12:04:44 AM »
Just to be clear about this, the 4 sets you measured WERE all original Honda parts?.
Don't mean to be a pedant here, it's just Hondaman says 2mm, AshimotoKO says 2.32 and you say 2.28mm. I know those digital verniers are not 100% accurate...maybe that is the difference. Either way, I guess any of the above is better than none.
« Last Edit: August 16, 2016, 12:10:40 AM by Old Moe Toe »
Offline AshimotoK0
« Reply #44 on: August 16, 2016, 12:42:17 AM »
I measured mine .. it was not NOS but still had the black finish and looked pristine and I measured it with a good 'ol British Moore & Wright micrometer. I think they are deffo more than 2.0 mm  but maybe Hondaman knows that if you make 'em a straight 2 mm you get a bit more 'nip' but still safe to not crack or overstess. Not gonna argue with the 'main man' anyway ;)
« Reply #45 on: August 16, 2016, 09:07:36 PM »
 Yeah, 220, 221. Whatever it takes.
Offline somesuch
« Reply #46 on: August 17, 2016, 12:14:50 AM »
Yes, all were original Honda parts. I did zero the calipers before measuring :)
