Author Topic: I can't get a grip!  (Read 2972 times)
Offline bluezboy
I can't get a grip!
« on: August 12, 2016, 04:32:55 AM »
 My hand grips will not stay on my bike so I need to know what  super duper glue that will hold those grips on, it's no fun when your grips start to come off while riding. :)! And it's pretty dang hot here in Georgia
Offline WhyNot2
  • I'm finally an
Re: I can't get a grip!
« Reply #1 on: August 12, 2016, 04:49:12 AM »
All of my bikes are like that.
The left one comes loose all the time, even after the local Harley shop reinstalled mine after my crash.
And definitely agree about the heat here in Georgia.
The bars on my CB350F still have the factory setup, and those are firmly in place.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: August 12, 2016, 05:32:51 AM »
LOL! Pretty dang hot here too! I've tried several different methods, and finally settled on two part epoxy. I first used a two part epoxy as I was preparing to head out for an extended road trip. The hairspray from the day before proved quite useless, as the grip came right back off before I even got the bike out of the garage. The schedule did not leave me with the luxury of time to wait another 24 hrs for adhesive to dry. Looking around the garage I spotted the two vials of 15 minute two part epoxy. I whipped up a small puddle, slathered it in the grip and on the bar, assembled the two, wiped off any excess, and 20 minutes later I was on the road. The grip has stayed put for a few years now and several thousand miles. I have had to remove a grip after using this method, so the grips can still be removed and reused. I just wouldn't do it more than I had to, since it does require some effort to twist them off.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: August 12, 2016, 06:49:26 AM »
Are you sure you don't mean your Aquanet there cal?  ;D
Contact Cement ($2) The kind you'd use on vinyl upholstery repair.
I just used this stuff to do my 550 seat cover, and d@mn...thats sticky stuff.
Locktite spray adhesive($6)  I used this with my Oury grips.
Spray in the grip and on the bar.  Slides right on.  Dry in an hour.  Solid.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: August 12, 2016, 07:17:05 AM »
Gorilla glue works great too. It's a moisture cured urethane adhesive that expands a bit as it cures so pop a cold one and wipe off the excess while enjoying your favourite beer. Win, win!
Jwexperience
« Reply #5 on: August 12, 2016, 07:26:53 AM »
I use electronics cleaner, clean the grip and bar good so there's no oils then give the bar a good spray so the grip slides on. The cleaner evaporates in minutes. The grip is usually stuck pretty well but not a pain to get back off.
« Reply #6 on: August 12, 2016, 09:02:12 AM »
Hell Wilbur, that Aquanet didn't werk on yer hair either!! LOL. I tried it and lost my hair but the grips stayed on.
Perhaps some 3M spray adhesive??
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #7 on: August 12, 2016, 09:37:56 AM »
Scott Grip Glue is basically permatex black.  Usually works as long as the bars and grips are clean going together.
I haven't had much issue with my emgo foamy grips wanting to migrate.
But my atv grips.  They're starting to move around, and I'm glad about it cause they're ready for replacement.  Considering Odi lock ons.
Offline bluezboy
« Reply #8 on: August 12, 2016, 09:50:05 AM »
Great suggestions, I should have stated that I'm using those old fashioned stock grips! Thank you gentlemen!
Offline carnivorous chicken
« Reply #9 on: August 12, 2016, 09:50:23 AM »
This. It's something specifically made for installing grips and it's not expensive. And it's not hair spray, shaving gel, Mennen speed stick, extract of quinoa, goat's tears, or whatever.
« Reply #10 on: August 12, 2016, 10:00:16 AM »
The spray adhesive might work well, I usually keep some of that on the shelf. It would depend upon the type of grip used. The grips I like best are an aluminum tube with a rubber insert. The rubber insert has tall pads that extend up through the aluminum tube that do an incredible job of quelling vibrations. The inside of the rubber tube that fits over the bar has many deep pockets inside and therefore does not make contact with the bars over 100% of the inner surface. This makes some of the less aggressive adhesives less effective in my experience on this particular type of grip. If the grips being used have a 100% contact patch on the bar, and the grip fit the bar snuggly from the beginning, then a less aggressive adhesive should do well. I do tend to exert a bit of force on the grips from time to time when I feel the need to pull myself "up on the pegs" when I see a particularly rough patch of pavement ahead.
I did that one time and discovered my handlebar clamps weren't quite as tight as they should have been!  :o  It took two weeks for the clench marks to relax out of the saddle...  ;)
TAMTF...
Wilbur
Projects:
Offline colvinry
« Reply #11 on: August 12, 2016, 10:23:56 AM »
Get some thin gauge wire and twist a few bands on and plant the sharp point into the grip. Motocross guys do it. I did mine like that and they stay put.
Offline bluezboy
« Reply #12 on: August 12, 2016, 10:40:59 AM »
 The wire looks like a nice solution, I'll look for some black wire since I don't want it showing, thankS!
« Reply #13 on: August 12, 2016, 11:09:23 AM »
Dont Overthink it....
 Masking tape spirally wound, add another layer if needed..
 No Drying time...
« Reply #14 on: August 12, 2016, 04:48:03 PM »
I use absolutely nothing, for real, you gotta make sure your bars are clean and grips are brand new.  Use compressed air to slightly inflate grips while pushing them on.  The only grips I have ever had slip or get loose had a mess of whatever kind of goopy glue.
Offline eigenvector
« Reply #15 on: August 12, 2016, 05:03:06 PM »
I have never had to use anything.  I've replaced the grips on 6 bikes and never needed grip glue.
Clean those bars with rubbing alcohol - get all the oil off them.  Clean them smooth and shiny.  I use canned air to puff them up as I work them on.
ProGrips best there is.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline 333
  • Time for change
« Reply #16 on: August 13, 2016, 07:44:42 AM »
Clean the inside of the grips as well. A clean handlebar is no good if the inside of the grip is in any way greasy or dirty.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline bluezboy
« Reply #17 on: August 15, 2016, 11:38:21 AM »
   you were right about overthinking it, I cleaned the barI really well, wrapped a few layers of electrical tape on it and finished it with a few strands of wire, even though I may not have needed it. End of problem and this post::!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #18 on: August 15, 2016, 11:46:47 AM »
ShoeGoo! Great for rubber grips (like my Ourys) especially on anodized bars (like my Renthals).
--Evan
1975 CB750K "Rhonda"
« Reply #19 on: August 15, 2016, 12:08:06 PM »
I should warn you e tape and heat can make it get all gooogey..that is why I use a drier tape..
Offline colvinry
« Reply #20 on: August 18, 2016, 10:15:19 PM »
Clean and wire. You'll be good to go.
Offline kpier883
  • is quite the
« Reply #21 on: August 23, 2016, 06:19:57 PM »
In cases where it keeps slipping, I spray some paint into the grip, Rustoleum or whatever black you have, and slip it on.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
