Okay, a new day and some rest.
Thinking out loud here.
I agree many of the aftermarket manuals are misleading for the carb specs. But, I'm not convinced yet that the carb chart is, or that the settings in the chart stated are "dangerous" for 77 CB550 owners with stock air filter and exhaust.
Has anyone ever found 77 CB550 carbs that were marked "X46A" ? I haven't. Nor have I seen them mentioned as found in forum postings.
The settings you've found seem to be the ones Honda used for the 500 version of the K3. I would expect them to be marked differently than those for the 550 K3, but how? If Honda had some sort of production marking issue, could they have installed CB500 carbs onto some 550s?
I'm not sure how to resolve this 30 years after the fact. Perhaps we have the basis for a Forensic TV show?
We ARE talking about stock settings. To legitimize the settings you've found, wouldn't we need to find a 77 550 with stock pipes and air filter, and then do a Dyno test to confirm the carb settings are proper for that bike? That would be convincing! It would also support many assumptions being made.
If I knew that the empirical cases you've found were 100% accurate, then the FAQ chart should certainly so state. But, it seems to me that there are variables existant in all cases?
You could make a FAQ submission to capture your findings. I simply don't know how to verify them from where I sit, or for that matter, the Honda source either.
I've been working on an expanded version of that chart, making measurements of needle tapers and orifice sizes throughout the carbs. I have pretty reliable examples of the earlier carbs. But, not the later ones, I'm afraid. Would you be willing to measure and add your findings to the FAQ chart? I was planning on notations of empirical measurements vs Honda source values. Here's the list of data points.
627B Carb setup number
Keihin (type 1) Carb type
40 Slow jet
100 Main jet
#2.5 - 4th groove Jet Needle and taper (Throttle valve)
272304 Jet needle number
5.57cm Jet needle OAL
1.25mm Jet needle diameter at tip
1.63mm Jet needle diameter at 1mm
2.06mm Jet needle diameter at 2mm
2.49mm Jet needle diameter at 3mm
2.52mm Jet needle diameter at 4mm
2.55mm Jet needle diameter at 5mm
2.60mm Needle jet orifice
0.9øX2 (1,2,3,4,5) Needle jet Air bleeds
1 +/- 1/8 Air screw opening (air Bleed)
none Pilot screw opening (IMS)
#150 Main Air jet
#180 Slow air jet
22mm (0.89 in.) Float Height
Or, perhaps the chart in the FAQ should be removed if it is too misleading?
