Support the site. Your contributions keep this site running.
The 78F engine came to me already converted and the bolt kept loosening up. Finally used longer bolt and washers to create space between the sprocket and the bolt. I believe the small movements of the sprocket back and forth were responsible for the bolt getting loose.Does it make sense?
I had a 77k motor that had a true correct conversion sprocket so I know they were out there at some time in the past. But whenever I try to order one I end up with one with the shoulder on both sides.Another option is to have a machine shop grind the shoulder off one side. Cheaper quality sprockets may be soft enough to mill.
The CB650 sprocket only has a shoulder on one side.
Quote from: Jerry Rxman Griffin aka MuthaF'er on August 14, 2016, 10:04:23 AMThe CB650 sprocket only has a shoulder on one side.Wow your right! http://www.jtsprockets.com/catalogue/model/520 http://www.jtsprockets.com/catalogue/model/564These two links show the cb650 1979 to 1981 with a 530 and the cb750 1977 with 630, the sprockets are the same width. I think we just found a direct conversion. I'll be ordering one of these cb650 sprockets when it's time and I'll report back with the results.My cb650 is a 1981, but it has a full 630 chain set up for some reason?
Quote from: 700504 on August 14, 2016, 11:30:28 AMQuote from: Jerry Rxman Griffin aka MuthaF'er on August 14, 2016, 10:04:23 AMThe CB650 sprocket only has a shoulder on one side.Wow your right! http://www.jtsprockets.com/catalogue/model/520 http://www.jtsprockets.com/catalogue/model/564These two links show the cb650 1979 to 1981 with a 530 and the cb750 1977 with 630, the sprockets are the same width. I think we just found a direct conversion. I'll be ordering one of these cb650 sprockets when it's time and I'll report back with the results.My cb650 is a 1981, but it has a full 630 chain set up for some reason?who knows who jacked around with parts over the years. All sohc650's cam with 530 chains. I seen on once with a drum front. NOT even close to factory.
