Author Topic: Light rust abatement  (Read 1015 times)
Offline eigenvector
« on: August 13, 2016, 11:58:51 AM »
Say you have some light rusting and barnacles on your frame.  Would the most expedient fix for that be sanding, primer, then finish coat.
That sounds like the fix - but I've never worked with paint before so I'm not sure if there's a extra step or if the rust barnacles indicates a problem that needs a different approach.  We're not talking huge areas - maybe patches the size of a quarter at most.  Generally at the weld joints where the metal is rough from the weld process itself and where water collects.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: Light rust abatement
« Reply #1 on: August 13, 2016, 03:55:25 PM »
I used one of those rust converter solutions that makes it a paintable surface, brushed on after carefully removing the rust with light abrasives, masked and painted it. Worked great, stopped the rust from spreading, did not catch the eye.
I have a motorcycle problem.
Offline eigenvector
« Reply #2 on: August 13, 2016, 04:00:07 PM »
That's simple enough then.
Rob
1977 CB550K
1983 VF750S Sabre
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: August 13, 2016, 08:10:50 PM »
+1 permatex rust converter.  If you want to go the chemical route that is.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: August 18, 2016, 01:51:20 PM »
75% of a paint job is in the prep.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: August 19, 2016, 09:36:26 AM »
I would say 85% but we are splitting hairs.  :)
Offline b52bombardier1
« Reply #6 on: August 19, 2016, 10:15:45 AM »
97.6 % of all estimates such as this are made up on the spot.  =8-)
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
