Author Topic: Nitrous on 50cc engine  (Read 16228 times)
Offline tbpmusic
Re: Nitrous on 50cc engine
« Reply #50 on: September 07, 2016, 01:32:08 PM »
The cause is most likely the fact that you're completely insane.....I applaud you sir.
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline simon#42
  • liverpool
« Reply #51 on: September 08, 2016, 10:10:30 AM »
no i dont think that is the cause , all two strokes are like that . 80% of the cylinder pressure is lost in the first few mm of exhaust opening .
you do need to find a cure , just throwing endless sets of reeds isnt going to work
its igniting in the crankcase because you have  very very oxygenated fuel in there due to the nitrous . any heat source will ignite it even the underside of the piston .
you need to reduce the nitrous untill it doesnt explode !
Offline frodef2
« Reply #52 on: September 08, 2016, 10:21:00 AM »
Yea, i just came back from the garage,  and the transfers open only when the piston is almost at the bottom. Not like the cast cylinder i have where they open almost at the same time.
You are probably right about the detonation, and i am unable to source drills small enough to make smaller jets. The current nitrous jet is 0,45mm (18 thousands) and the fuel jet is 0,40mm.
the new smaller jets are in the mail, and i think i'm going to attend the race and do one run.
Thanks for the advise.
76' Supersport
Offline vfourfreak
  • Do you think that's wise
« Reply #53 on: September 08, 2016, 12:27:45 PM »
You could be right mate, but frankly I can't think straight - I'm just in awe with what you are doing !!! Just wish I was there to help.
You must have very tolerant neighbours and understanding police. That helps  :)
Keep up the good work.
Kev
Offline simon#42
  • liverpool
« Reply #54 on: September 08, 2016, 02:12:14 PM »
frode one last thing to try , use a larger fuel jet . a richer mixture will be harder to ignite it might calm things down
good luck mate and whatever happens well done for all your effort !
Offline Lostboy Steve
« Reply #55 on: September 08, 2016, 05:40:05 PM »
Lol that'll do it.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #56 on: September 08, 2016, 05:44:20 PM »
What about some super high octane race fuel as well?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #57 on: September 08, 2016, 09:14:50 PM »
I am using the smallest jet in the kit. And i run lower bottle pressure than recommended by NX (nx says 1050 psi in the manual), and i try to keep it at 950.
The nx jet size is 18 for the n2o and 16 for the fuel.
Is it advisable to let the n2o pressure go even lower? I assume the flow is related to pressure.
The flow of n2o should be proportional to the pressure, and if the extra fuel is added using a "siphon" type nozzle, the flow of fuel should also be proportional? At this point, I would try reducing the pressure to as low as 550 PSI; you can't do any more damage than you already have suffered. ;)
Offline frodef2
« Reply #58 on: September 09, 2016, 03:22:22 AM »
I am already running VP racing C14 fuel. Should be enough.
Frode
« Last Edit: September 09, 2016, 03:24:01 AM by FrodeF2 »
76' Supersport
Offline frodef2
« Reply #59 on: September 09, 2016, 02:30:34 PM »
Update from the last trial run's.
first run: I swapped the reed for a new 0,12mm and changed the angle of the nitrous jet. i now points to the side of the intake pipe, not straight down the pipe as before.
I tested one high rpm pull, and almost immediate stuttering.
second run:
swapped the reed for DUAL 0,12mm reeds. I stacked 2 reeds on top of eachother. i switched the nitrous and fuel jets, so now the 16 jet is nitrous and the 18 is fuel. i aimed the pirana to the back of the reed.
2 small high rpm tests, that seemed promising, so we thought what the hell.. lets do a run with nitrous on from the start.
and wouldn't you know. it worked like a charm. only started to stutter at the very end of the pull.. By the way, the distance between the lightposts are 50 meters. So by the time it starts breaking up, we are passed 100meters.
This time there where no missfires, and still the reeds took a beating, but much less than before and we ran the nitrous longer. I am starting to think that the damage to the reeds are caused by the opening action. That the nitrous is actually Blowing the reeds open with enough force to bend the reeds. I will upload a picture of the reeds with tapatalk in a sec.
76' Supersport
Offline frodef2
« Reply #60 on: September 09, 2016, 02:34:10 PM »
As you can see. The outlining of the reed supports have rubbed the reed. And the curved part of the reed only start outside the support.
The bending is also much less on the bottom reed. Like it was supported by the top reed
I will go to the shop early tomorrow and make a longer and wider reed stop.
76' Supersport
« Reply #61 on: September 10, 2016, 02:17:11 AM »
That last run looks way more promising mate, well done! ;D
Offline frodef2
« Reply #62 on: September 10, 2016, 07:42:07 AM »
Good news from the race. We did not win. But we did not break any reeds on 2 runs and 1 test and tune.  The racing was straight ladder, and very little downtime between the races so we didnt have time to even switch back the jets.
We ran all races with 16 nitrous and 18 fuel jets.
Here are the reeds after three 100 meter pulls. No damage at all.
Here is a picture of the winner. Used to be a yamaha aerox scooter.
76' Supersport
Offline simon#42
  • liverpool
« Reply #63 on: September 10, 2016, 08:41:01 AM »
well done !     bloody hell the winner took it very seriously didnt he !
Offline vfourfreak
« Reply #64 on: October 10, 2016, 12:33:32 PM »
Lovely lunacy !  :)
Kev
Offline Gearheadgreg
  • Jamestown Rhode Island
« Reply #65 on: October 11, 2016, 06:01:55 AM »
Awesome ! just found this thread..sorry for the late reply,,I have been using Nitrous for 20 years I grew up 3 blocks from NOS systems in Cypress Cal back in the late 1970's they were very much the pioneers of NOS , we were using dry systems back then breaking small Chevy's then they added Wet Fuel and success, When i set up my Supercharged GL 1500 with Nitrous i spoke to the Tech at NOS and my App,, we went 2 size Larger on Fuel jet than standard Carb app.. Also stepped up Main Jetting on Carb larger than any Jet offered by Sudco with a reamer,, Your on the right track with switching your jets as you did..you may even try one more step in Fuel jet to prevent detonation keeping cylinder temps down with fuel added ..HAVE FUN !!
2001 Honda Supercharged Valkyrie   <iframe width="480" height="360" src="http://s1218.photobucket.com/user/meloafer/embed/slideshow/"></iframe> Just having some fun
Offline Yoshimatic
  • The Stable
« Reply #66 on: October 25, 2016, 11:49:59 AM »
I love this thread, its the best seeing things like this.......
1969 GL175 twin
1970 CB750 K0
1971 CL350
1975 CB750F1
1977 CB750F2
1977 CB750A (original condition)
1977 CB750A (836 Cafe Racer)
1978 CB750F3
