I needed a battery for my 78 CB750F. It sat for about 2 weeks during vacation/other priorities.
Starting was getting slow. Battery was about 2 years old, no problem really.
Replaced the battery with a standard lead-acid type.
After I started it and warmed it up I decided to install the Rick's Regulator/Rectifier unit that I bought a few months back.
Easy plug and play factory connector for the Rectifier.
White, Green, Black OEM type plugs for the Regulator. Straight forward.
Started up, revved to 3-4K RPM and found no charging voltage. 12.4DCV at best.
Idle was lower.
I followed the notes from Rick's, and tested power supply with Key ON at the Black "sensor" wire at the Regulator portion.
I was getting 11.4 volts at the Regulator. 12.4-12.5 directly at the battery posts.
A whole 1 Volt being lost through the system.
From my understanding, the alternator current can be lost to excess current draw and not charge the battery properly.
I inspected every connector. All were recently checked and treated with dielectric grease.
Frame ground and ground by coils both good.
Removed the headlight looking for chaffed or pinched wires. Nothing wrong here.
Found the voltage creeped back up to 12v when I unplugged the connector between the Main harness and the Right-hand Start/Stop switch.
I found the voltage would drop to 11.2 and then jump back to 12.1 or so just by changing the Engine Stop switch.
First big question, Is that normal?
I ran out of time. I know my next test should be resistance of the alternator assembly.
I got a little ahead of myself checking wires, but I figured I would find a loose ground, loose connector, pinched wire. etc..
Double checking with this guide
http://www.hondachopper.com/garage/troubleshooting_charging_system/troubleshooting_charging_system.pdfDiagram
http://manuals.sohc4.net/cb750f/technical_reference/WD750F_78.jpg
