Author Topic: Allen bolt carb kits  (Read 2514 times)
Offline Chris Liston
« on: November 26, 2006, 04:44:33 AM »
Anyone know of any allen bolt carb kits out there for our bikes.  I hate soft phillips bits that are on the caps and bowls.  We just purchased an allen set for my brothers Thruxton and I figure it would be great for our bikes too.
1976 CB550F Cafe in progress
Offline Geeto67
  • A grumpy
Re: Allen bolt carb kits
« Reply #1 on: November 26, 2006, 05:06:50 AM »
I assume you are talking just the float bowl screws. I can't think of other screws in the carbs that aren't special or need a special head design to clear something that moves. At one point I was working on a set of 550 carbs so often that I went to an industrial fastner supply house and made up my own set out of stainless steel. I am on good enough terms with them that if this is something people want I can have a few sets made - Just have to bring them the screws to match up.  I don't know if one of those full allen kits would cover that (not just the engine kit but there are kits out there that claim to replace just about ever screw in the bike), but the engine allen kits I buy don't.
Maintenance Matters Most
« Reply #2 on: November 26, 2006, 05:20:43 AM »
Yeah, basically the float bolts screws and top caps screws.  Didn't think of bringing them to a fastener place and just matching up.  I'll look into that locally.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #3 on: November 26, 2006, 05:36:39 AM »
Here's a place I've used.
http://www.fastener-express.com
–Captain Horatio Hornblower
www.thehairynickel.com
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: November 26, 2006, 05:58:05 AM »
I got mine @ home depot. got slightly bent, but they had them. Fastenal has them too.
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
« Reply #5 on: November 26, 2006, 07:23:30 AM »
Just looking at my parts 550 parts manual.  It looks like the float bowl screws are 4mm x 10mm  and the top caps are 5mm x 16mm.  What is the thread pitch.  Would like to order first without pulling the carbs apart.  069A 550F carbs btw.
thanks
« Last Edit: November 26, 2006, 07:26:10 AM by Chris Liston »
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #6 on: November 26, 2006, 12:03:33 PM »
Hotwire750
« Reply #7 on: November 26, 2006, 03:25:21 PM »
I just replaced a few of the stripped out phillips screws on my carbs (550k) last week. If I remember correct they were 3 x 0.8 x 12mm for the bowl and 3 x 0.8 x 20mm for the top plate.
Offline dagersh
    • Photos
« Reply #8 on: November 27, 2006, 11:45:28 AM »
Chris,
This would be a great thing to have around, especially at $1.50!
http://www.boltdepot.com/product.aspx?cc=26
Gersh
« Last Edit: November 27, 2006, 11:48:58 AM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline SD750F
    • My Business Site
« Reply #9 on: November 27, 2006, 11:54:09 AM »
CB650Tex
« Reply #10 on: November 29, 2006, 04:21:53 PM »
Am thinking about using:
http://www.stainlesscycle.com
Their prices seem pretty reasonable, they seem to have a pretty good range and you can buy as few/many as you want.
Anyone had any experience with them?
« Reply #11 on: November 29, 2006, 05:16:33 PM »
Great find.  They don't have the 550 listed on the site but I emailed them.  They do have a universal kit for mikuni and keihin carbs.  I'll post back when I here from them.
Thanks
Offline steakCB550K
« Reply #12 on: July 13, 2012, 08:21:24 AM »
Sorry to bring back a dead topic, but ChrisListon did you end up purchasing these SS bolts from stainlesscycle?  How did they turn out?
thx, I am looking to do the same to replace my stripped out phillips in my pd46c carbs.
77 CB550K
78 CB550K
77/78 cool 2 member
Offline AEngelsrud
    • engelsrud.com
« Reply #13 on: July 13, 2012, 08:59:05 AM »
ACE Hardware has stainless hexbolts and washers in metric.  That's where I picked up a set for my carbs.
Aaron
Offline oldfart
    • The Motorcycle Project
« Reply #14 on: July 13, 2012, 09:15:23 AM »
I know this is not a popular view, so flame away...  :-). But using Allen (technically, socket head) screws is carburetors is a bad idea on several levels.  Just for starters, they are too easily over-tightened.  If you must use them, tighten them with an Allen screwsdriver, not an l-shaped Allen wrench.  Virtually all the pulled threads I see on carbs are due the use of Allens, and this is a trend I have seen for over 40 years.  If you are tearing up the stock Phillips scews, you probably need to get a new screwdriver.
http://www.motorcycleproject.com/motorcycle/text/carburetor_thread_repair_v5.swf
http://www.randakks.com/TechTip59.htm
« Last Edit: July 13, 2012, 09:29:30 AM by oldfart »
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
Offline steakCB550K
« Reply #15 on: July 13, 2012, 11:50:03 AM »
Thanks for the advice Aenglsrud and oldfart!
77 CB550K
78 CB550K
77/78 cool 2 member
Offline Geeto67
  • A grumpy
« Reply #16 on: July 18, 2012, 03:25:53 AM »
and remember, the stock screws in the bike are not actually Phillips (unless they have been changed), they are Japanese Industrial Standard. So when you buy a new screwdriver to work on your bike make sure you buy a JIS set as well:
http://www.instructables.com/id/When-a-Phillips-is-not-a-Phillips/step10/JIS-Japanese-Industrial-Standard/
Offline Gman
« Reply #17 on: July 18, 2012, 11:40:50 AM »
Aaron
+1
I just went to Ace for some float bowl screws - they had them in SS, both phillips and allen.  I went w/phillips for the simple reason 0.20/each vs. 0.85 for the allen.  I believe they are M4 x 10mm.  Cheap, easy, no shipping...
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline bert96
  • past ride
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
