Author Topic: SOHC Four Electronic Ignition - I Don't Get It  (Read 11097 times)
Offline b52bombardier1
« on: August 16, 2016, 06:09:26 PM »
Hello,
  I simply don't understand the attraction around here for any kind of SOHC Four electronic ignition.  People seem to have constant trouble with them and many threads and discussions around here are devoted to solving those problems.
  The original equipment points ignition . . . much, much less so. All of my Honda bikes have plain old points ignitions that are relatively straightforward to repair and trouble free after replacing condensers and points. Set the gap and timing and you are done.
  So I don't understand . . . what am I missing here?
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline Steve_K
Re: SOHC Four Electronic Ignition - I Don't Get It
« Reply #1 on: August 16, 2016, 06:27:11 PM »
I have points with a Hondaman ignition on mine.   But, I do like that my newer bikes that have electronic ignitions.  They also have had fuel injection, too.  Points are not an issue for me and I am comfortable with them.
It was simple for me, do what suits you.  I just want to ride  mine.
Steve
Steve_K
« Reply #2 on: August 16, 2016, 06:32:42 PM »
Points are very reliable, but do wear. My box slows that problem to a crawl, while also improving the spark when cold, and up to 12k RPM. And, if it fails, you can unplug the 4 wires and plug the points back in in under 2 minutes, and hit the road again.
Offline USMC5811
« Reply #3 on: August 16, 2016, 06:37:39 PM »
The first tools I ever kept in a car were a screwdriver and a book of matches. I've never had room for a diagnostics computer in one yet.
I like points.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: August 16, 2016, 06:42:37 PM »
I have used an electronic ignition in several CB750's without issues, and my K8 CB750 Dyna ignition has been in place for over 40,000 miles trouble free. I have not had to change the settings on my K8 ignition since it was installed 40,000 miles ago.
I will agree, the points/condensers are more than adequate, and any motor that I'm bringing back to life I will set up with points/condensers for initial break-in just to keep my dual point ignition set up skills sharp. I would just rather not have to address point gap and timing on subsequent tune ups. I do keep a gapped and timed (outline the mounting screws with a sharpie) points plate in the saddlebag for trips of 400 miles or beyond, but I have never had to use it. Most of the trouble threads I've seen often involve some sort of error or misunderstanding on the part of the installer. The most recent one involved a coil bracket that was installed backwards and was shorting out the coil connection.
So for me, it is the "set and forget" nature of the electronic ignition. I luv'em!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Lostboy Steve
« Reply #5 on: August 16, 2016, 06:44:09 PM »
I like points.
Like hondaman said his basically eliminates wear. Its nice to never have to change or touch them again. I don't mind points either, but for the $70~ why not?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
DH
« Reply #6 on: August 16, 2016, 07:06:37 PM »
Points pit, wear, and arc. They work fine for a long time, but performance slowly degrades. This can lead to misfires,(pitting) and retarded ignition timing as the rubbing block and contacts wear, and sometimes moisture will affect performance. I still have em on my
750 AND 550 both. I'd like to convert to Hondaman's system for its simplicity and the fact that you can revert back to stock.
I'm thinking that his system gives better spark duration too, and that's a good thing. An electronic transistor is much more
consistant, efficiently turning the coils off/on repeatedly than a mechanical device I would think.
« Reply #7 on: August 16, 2016, 07:27:22 PM »
I've only had to set the timing on my Gerex ignition twice in the 37 years I've had the bike, and both times were because I had to remove it to split the cases. ;D
« Reply #8 on: August 16, 2016, 08:00:39 PM »
I need to focus more on the people that are running electronic ignition successfully.  However, they . . . rarely complain.  It's those that have trouble that I have read too much about.
With the 500-1000 miles that I put on a bike each year, points do very well.  Maybe if one of these bikes was a daily driver, yea, I might feel differently.
  But thanks for the comments.  I understand a little better now.
Rick
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #9 on: August 16, 2016, 11:43:09 PM »
CycleX sells a performance tuneable setup that seems to kick ass.  It's been discussed here.
Offline flatlander
« Reply #10 on: August 17, 2016, 03:50:31 AM »
you don't hear as much from those that don't have any problems ;)
Offline rotortiller
« Reply #11 on: August 17, 2016, 04:30:08 AM »
I have the Hondaman ignition on mine and it performs the same as stock regarding  engine power. It's proven reliable over 3 or 4 years and 20,000+ miles. The only benefit is the points don't burn. The rubbing block still wears and you will still need to make routine adjustments for that. If you don't ride a lot it is kind of a waste of money and effort, if you ride a bunch then it can save you work and parts over extended time. Remember points can be filed/dressed to extend their service life. I still check my timing once a year and the HM ignition has not changed that. I don't dress the contacts any more, just clean them. Personally if I did it over again, I'd try the Tytronics system just to piss off a bunch of nutswingers LOL
« Reply #12 on: August 17, 2016, 05:04:14 AM »
I installed Pamco on Dorothy and did not touch it for 25 000 miles - try that with just points.
Offline lrutt
« Reply #13 on: August 17, 2016, 05:43:04 AM »
Only bikes that ever left me stranded were bikes with electronics. No bike with points has EVER let me down. I have never retrofitted any bike to electronics. Guzzi, Norton, Triumphs, old Hondas, Old Yamahas and Suzukis, even my 1953 MG TD still run the original type electrics. Reliable as a rock.
« Reply #14 on: August 17, 2016, 05:51:45 AM »
I'll agree, but if it were to fail, Hondamans takes literally less than a minute to revert back to stock.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline USMC5811
« Reply #15 on: August 17, 2016, 05:01:44 PM »
Where does one find this?
I've googled but nothing looks like that, so I'm scratching my puzzler.
« Reply #16 on: August 17, 2016, 05:22:41 PM »
I like points.
Boy, you just brought back massive memories of my 390 Fords and Galaxies!
:D
Offline USMC5811
« Reply #17 on: August 17, 2016, 05:37:30 PM »
I like points.
:D
'71 Ford Pinto - engine was technically a "SOHC 4" and even had a label on in stating "2000cc" so I figured it's ok to talk about it here LOL
Online CycleRanger
  • No comment about being an
« Reply #18 on: August 17, 2016, 08:41:45 PM »
There's a thread about these over at the twins forum.
http://www.hondatwins.net/forums/50-electrical-discussion/44581-tytronic-ignition-2.html
Offline rotortiller
« Reply #19 on: August 18, 2016, 01:24:23 PM »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #20 on: August 18, 2016, 01:29:50 PM »
Another points vs Electronic Ignition thread? It's getting as bad as the oil threads!
If you don't like EI then don't buy one. That's your opinion that's fine. I don't agree with you so let's just agree to disagree. I've had many old vehicles, cars, boats, motorcycles that I switched over from points and never missed a beat.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline jonda500
« Reply #21 on: August 18, 2016, 05:56:25 PM »
Yes, I don't really get it either! Having been stranded far from anywhere due to an intermittent CDI fault and then when I returned to pick up the bike, it had been stolen, I would never ever convert a points bike to electronic ignition as I like to know how my stuff works and be able to fix it if the points ever fail (but I have never had a points related break down).
John
A starter clutch thread:
« Reply #22 on: August 18, 2016, 06:31:26 PM »
The only true CDI ignition that has been mentioned here is the Gerex; the Dyna S, Pamco, and Power arc are all inductive systems, which store the energy in the coils, rather than a capacitor.
« Reply #23 on: August 18, 2016, 06:56:27 PM »
Sooner or later I will be making the pickup-coil version of mine, which will be "all electronic" in a way. But, it will still have the revert-to-points-quickly feature, 'cuz I want it! Speaking as a lifelong electronics engineer and designer, points are usually more reliable than the too-quickly-designed electronic versions we sometimes see (in many things, not just ignitions) today. So, mine will not have electronics on the hot points plate (which was the demise of my built-in timing LED for this unit), but purely mechanical parts, once I get the temperature issues worked out - that's the tough part!
Old guys and old stuff rule!
:D :D ;)
« Reply #24 on: August 18, 2016, 07:11:23 PM »
:D :D ;)
It's true, and I have a T-shirt that proves it! ;D
