Author Topic: So I thought my bike was a K but does this mean it is an F?  (Read 1401 times)
Offline RainCityRider
  • BRAAAP!
  • instagram @raincityrider76
« on: August 18, 2016, 04:33:06 PM »
Was reading a post earlier and found a thread that made me think my 1978 CB750 may be an F model. Not a K like I had thought. But as Im sure you can guess I am not the first owner so who knows what is original and what has been swapped. Is there any way to tell from other parts or the VIN number? Or rather how can I tell from the VIN or engine numbers.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Re: So I thought my bike was a K but does this mean it is an F?
« Reply #1 on: August 18, 2016, 05:21:53 PM »
Engine and VIN number will usually work plus pictures help.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: August 18, 2016, 06:02:56 PM »
Could be both. People combine parts from different bikes all the time. Doea your frame have the ID tag on the neck?
« Reply #3 on: August 18, 2016, 06:33:47 PM »
I thought a PD 42 is the proper K8 carb??
  • BRAAAP!
« Reply #4 on: August 18, 2016, 07:51:46 PM »
Apparently there is a PD 42A and PD 42B? saw it in a thread earlier. I will look for it.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
« Reply #5 on: August 18, 2016, 08:12:28 PM »
Kickstand is further ahead on K and under frame..on the F its further back and a bit up the bend.. Do you have disc or drum out back ?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #6 on: August 18, 2016, 08:51:37 PM »
Frank is right again.  +1 kickstand is a dead giveaway
  • BRAAAP!
« Reply #7 on: August 18, 2016, 10:27:43 PM »
Drum in the rear
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #8 on: August 18, 2016, 11:02:05 PM »
Bike in your avatar is a K. :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Old Moe Toe
« Reply #9 on: August 19, 2016, 01:42:06 AM »
Yes it might have a K frame but like mine it might have a F2 or k7 motor in it.
Engine number should shed SOME light on it. However still not sure what mine is CB750E 2613894. I have seen F2's with lower engine numbers.
« Last Edit: August 19, 2016, 01:46:50 AM by Old Moe Toe »
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #10 on: August 19, 2016, 07:08:46 AM »
Rain ; As long as nothing (numbers wise) has been altered (illegally modified/changed), this should answer your questions as to what you've got. http://www.hondachopper.com/engine/engine_timeline/timeline.html
This will show you what your numbers frame/motor mean. Hope this helps.   ...cougar...     P.S. This is for ID'ing the frame/motor, anything else can be modified , added , deleted , you get the idea.
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
  • BRAAAP!
« Reply #11 on: August 19, 2016, 08:17:25 AM »
Sweet, I'll check this out. Thanks Cougar!
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
