Author Topic: I think I found where my carb leak was coming from. Doh! HEPL!  (Read 1275 times)
Offline RainCityRider
  • BRAAAP!
  • instagram @raincityrider76
So I was quite carefully cleaning the float bowl and as soon as there was an pressure on the overflow tube (if that is what it is called) it broke at the base  :'(
Can this be repaired or replaced or do I need to scavenge a part from my other carb?
I'm 99.9% sure it was cracked and about to go. If you look at the pic of the base of the tube the brass has corrosion everywhere but a sliver that must have been holding it on.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: I think I found where my carb leak was coming from. Doh! HEPL!
« Reply #1 on: August 18, 2016, 08:52:28 PM »
Check ebay for salvage parts.
  • BRAAAP!
« Reply #2 on: August 18, 2016, 08:54:13 PM »
Can the tube be replaced or do I need to get a whole new float bowl?
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Offline Gene
  • Chat enuf you too can be a
« Reply #3 on: August 18, 2016, 10:02:15 PM »
New bowl is your best bet.  I have heard of these being soldered/brazed back in.  But that seems like a lot of work. You should be able to find a replacement bowl.
While you're at it - check for leaks with the bowls/overflows while they're off.  Could be more like that.
Quit breaking your bike! ;)
*1973 CB750K3 (Bow)
  • Holy Cow! I'm a
  • BRAAAP!
« Reply #5 on: August 19, 2016, 12:11:51 AM »
I have extras. Just a bummer. Had to rob from another carb. Gonna have to hit the used bike shop.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Offline harisuluv
« Reply #6 on: August 19, 2016, 03:15:39 AM »
Pm me I have dozens. I need to know which cylinder it is for.
