Author Topic: Rear break broke...  (Read 1986 times)
Offline waldezy
Rear break broke...
« on: August 19, 2016, 07:05:36 PM »
So...this happened today. After riding home from work, I'm starting to slow down for a left turn and use both breaks as I normally do. But this time something is different. When I pressed the rear break pedal it rejected my input violently then "POP" - then the pedal was extremely firm and didn't work. When I got home, I look at it and this is what I see....no more linkage. What on earth could have happened?!
Offline waldezy
Re: Rear break broke...
« Reply #1 on: August 19, 2016, 07:06:27 PM »
Another view...
Offline CycleRanger
  • No comment about being an
« Reply #2 on: August 19, 2016, 07:20:20 PM »
Where is the rear brake stopper arm?  Looks like the bolt fell out where it attaches to the brake plate.
Offline 540nova
« Reply #3 on: August 19, 2016, 07:24:39 PM »
Agree, your bolt came out, and the outer plate rotated. BTW, where's your axle nut cotter pin?
1974 CB450, 2006 CBR1000RR
Offline waldezy
« Reply #4 on: August 19, 2016, 07:27:01 PM »
I took it off as I was going to start taking the wheel off - then decided to leave everything and take a pic first and throw it up on here.
Offline waldezy
« Reply #5 on: August 19, 2016, 07:28:27 PM »
The arm is there - just need to look hard. It's all painted black.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #6 on: August 19, 2016, 07:30:22 PM »
Yeah looks like that brake arm bolt sheared off with a bit of vengeance
Offline waldezy
« Reply #7 on: August 19, 2016, 07:33:17 PM »
Dang - just when I thought I was "done" with the build. I've almost stopped the oil leaks - almost - and then this! I guess no one is ever truly done aren't they?! Thanks for the help!
Offline waldezy
« Reply #8 on: August 19, 2016, 07:42:00 PM »
Tell me about it. That is so crazy - I wonder what caused it to shear? Perhaps it vibrated loose or something. It was a bad day for the bike today. During the ride I found my pegs were coming loose as well.
« Reply #9 on: August 19, 2016, 08:46:25 PM »
Its a special shouldered bolt.. Do you know what was in there? Not the place for a hardware store cheapo bolt..
 You need the proper bolt for brake arm
 The brake rod, the brake actuating arm
 Maybe the bushing pivot the rod goes thru..
« Reply #10 on: August 20, 2016, 03:51:47 AM »
Or there was no cotter pin and the nut came off
Offline jas67
« Reply #11 on: August 20, 2016, 06:12:55 AM »
I had that happen on a CB360 a few years back.    I definitely made sure to get the correct castle nut and cotter pin to make sure it didn't happen again (on that bike, there was a stud in the arm of the backing plate).
It is likely that it just had a regular nut on it when it happened.
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
Offline USMC5811
« Reply #12 on: August 22, 2016, 08:16:36 PM »
I can empathize.
Lost rear bolt on torque bar, drum rotated, actuator cam sheared off about 6 miles from home at dusk.
I almost expected it to start raining.
« Reply #13 on: August 23, 2016, 05:11:27 AM »
Lucky indeed.
« Reply #14 on: August 23, 2016, 11:48:31 AM »
+1
Offline nobody
« Reply #15 on: August 24, 2016, 08:47:09 AM »
If this or something similar to this ever happens again, I would recommend pulling over to assess the damage rather than riding all the way home first... broken parts on a two wheeled machine, always a safety risk.
74 cb750k
Offline Bodi
« Reply #16 on: August 24, 2016, 06:07:51 PM »
Not uncommon. The torque arm comes loose, you touch the pedal and BAM! The geometry works so that the brake plate turning tightens the brake, meaning more force to rotate the plate, meaning tighter brake... extremely dangerous on wet pavement or dirt/gravel where the tire will skid before something breaks to release the brake.
The torque arm attachment points are part of my pre-ride check: fasteners secure and cotter pins in place. Do not substitute in standard bolts if you don't have the special parts.
