Like I said, I took the block to my good friend Chris to get the crack sorted. He opened it up, sat on his comfy stool, and did his thing....
After cleaning up....
The evidence of porosity is clear to see, but he's done a good job I reckon.
Now, I've been troubled, cut to the quick even, by the implication from certain commentators on this thread that I don't know a measuring instrument from a musical instrument, so I conducted a little experiment. I mounted the barrels (after which I placed the barrels
) on to the crankcase to see if the material removed during the clean-up would potentially cause a leak at the joint....
Using a non-Pommy (Starrett) set of feeler gauges, I ascertained that there is less than .02mm gap at the joint. Moving the gauges around the base, this is no more than anywhere else, which as far as I'm concerned proves two things; 1), I haven't removed too much material from the sealing surface, and 2), they never sealed properly in the first place. To quote a certain Aussie gentleman, this is probably how it came out of the factory!
So then the next logical step is to work out if it will actually seal with a gasket. The base gasket
that came with the gasket set measures twice(ish) the width of the gap....
So I'm thinking it's going to be ok. (Especially if the gasket gets a liberal slavering of Hondabond both sides
). Next job is fitting the new pistons.
As an aside, followers of this sordid tale (yes, both of you
) will undoubtedly have been awed and bewildered by my engineering and tool-making prowess. As a special offer to SOHC forum members, I am making available my bespoke tappet block insertion jig, complete with NASA approved insertion tool. If it generates enough interest, I may expand the range to include Hardly Davidsons. Get your orders in quick, I don't expect these fine examples of British engineering to be hanging around for long. Princess Kate is already getting grumpy that I may have to focus my attention elsewhere, but as I tried to explain to her, at 63 she'd be a lost cause, whilst an old British engine is worth fighting for....
