Author Topic: Jakal cb550 project  (Read 40585 times)
Offline Darren Jakal
Re: Jakal cb550 project
« Reply #25 on: September 04, 2016, 10:57:25 AM »
I love this bike. It's so much fun. I have to remember that this is supposed to be a low-budget winter project and keep my enthusiasm in check. It's pretty easy to drool over pictures and spend internet pesos.
I spent 16.00 bucks on new fasteners for the original carbs and I can't keep from wanting to get a good look into the new PDs I picked up for $40. But dam these JIS fasteners! I know I'll wind up spending more $$ on the fasteners I wreck so I stopped everything and ordered a set of JIS drivers from a place called GoFast Innovations. They are in Canada so the $24.95 CDN including delivery for a set of three seemed well worth the money.
So, it's cleaning, checking, finding parts, ordering stuff and thinking about what this bike is going to be. Like I say it's low milage, but short-term abused (most likely stolen and crashed) and I really don't like the original seat with backrest. The front end is also wrecked so that will need to be re-done.
When I started looking for a bike I had thoughts of cafe racers in my mind, because they do look cool (I do like lots of original Honda styles, but this one doesn't work for me). However, since I started into this project I've gained a great appreciation for the design team's intentions and when I look at the bike as a whole I think there is much more here to save than to change. The air box and triangle set-up is pretty cool from an industrial design perspective when you think about when these were built (and it all works together to perform well) .
The guy I bought the carbs off of had a bay full of old Japanese bikes that he was finding in cherry condition in garages around the prairies that he was sending back to England. He didn't like the Hondas because he thought they were plastic crap (he mentioned Yamaha making musical instruments). When I was a kid in the 70's a Honda was the first bike I ever rode (XR75) and everyone thought they were solid bikes for a good price (but I owned a Yamaha YZ125 anyway as the mono-shock was just too cool).
So while I will be redoing the seat and rear end along with the front end, handlebars and controls I will keep it pretty much mechanically stock (safety upgrades like swing arm bushings, steering, brakes, tires, etc yes). I'll try to stay within the original design brief (smooth, quiet and dependable ride), but update the body style to make it a bit more modern.
See how it goes.
« Reply #26 on: September 04, 2016, 01:47:01 PM »
OK I couldn't help but take a look inside.
I'm looking at posts about primary chains now. This project is taking over.
Cheers, Darren
« Reply #27 on: September 11, 2016, 12:37:53 PM »
First off thanks to several members for help with my alternator rotor. My bike was missing all alternator parts except for the rotor and then I watched some youtube stuff on checking rotors and soon I'm thinking that it needs to come off.
Big relief to discover that it's just a chunk of iron that spins and that the field rotor and stator is where the magic happens.
Anyway, I'm still waiting for my JIS drivers but I could not help wanting to get a look inside the clutch housing. Off course the lower bolts all came out with a manual impact driver with a posidrive bit but all the upper ones were rusted in and I finally drilled off the heads.
I've never had the bike running and the clutch lever (without the cable) was very hard to pull so I thought something might be up with the clutch. Well it looks brand new inside, but the clutch adjust was screwed out so much that the threads were starting to catch in the slit end. I loosened it up and it everything inside the housing looks ok (not much to see really).
I pulled the clutch out and was able to disassemble all the plates and pads. It was oily but looks pretty much like new.
So, what do I do? I've read about "taking the glaze of the steel discs" and about soaking the pads in both gasoline and oil.
I've measured the springs (ranging from 36mm to 36.28mm) and will check the metal discs for flatness and thickness, but what would be good practice for getting this thing back on the road in basically original shape. Grease the push rod, check, but what else? Brass brush the steel plates and soak the pads? In gas or oil or what?
Cheers, Darren
« Reply #28 on: September 11, 2016, 04:38:11 PM »
The only reason oem swingarm bushings wear out is because no one ever greased them.  If yours are good, just keep em greased up.
« Reply #29 on: September 11, 2016, 08:54:52 PM »
Hi Sean,
Yea it's one of those things. I want to take the bike apart because it has started to rust and I want to protect it. When I first got it home I was thinking of a rattle can or tremclad paint job, but it's almost to pretty to not do something a little better (project creep).
So I read these forums and make big plans, but yea, sometimes plans need to be reconsidered. I decided to get some swing arm bushings and head set bearings from twowheelfrank as they like a pretty good deal (they should be coming soon). I figure if I have the swing arm out to have it powdered coated then I might as well do the bushings and bearings. Keeps me from planning to do it later.
Anyway, I'm all ears when it comes to what really is important to do when you have a chance (like now with this revive project). I have the clutch out and I'm reading about Hondaman clutch mods (The kind of mods I like, cheap and I can do them myself).
So, anyone have any must-do's or don't bother's. I'd like to hear them.
« Reply #30 on: September 12, 2016, 05:11:27 PM »
The JIS drivers came in the mail today and I got to look inside the new carbs.
Better on the outside, but worse on the inside. The bowls were filled with some kind of rusty powder. Not sure how they'll clean-up but I'd really like two functioning sets of carbs at the end of it all.
Still looking into Hondaman clutch mods. Any 550 riders out there think these bikes need help here? I've read about chamfering the existing holes, drilling new holes and grooving the area around the holes. As well as deglazing and deburring plates. Not sure what I'll do. Any advice?
Darren
Offline calj737
  • I refuse...
« Reply #31 on: September 12, 2016, 06:42:09 PM »
Square cut plates are probably the only modification I'd make if I were adding HPs to the motor. Else, I'd probably insure my plates and discs were up to snuff and button her up.
« Reply #32 on: September 12, 2016, 07:34:12 PM »
Thanks calj737,
Plates are flat and all measure around 1.62mm (except for the double one at 4.75mm).
Friction discs are all about 2.7mm (+ or - .01mm). The only numbers I have are for earlier 350 and 500 or 550 4s from Clymer (72 - 74). They state 2.3mm for the 350F and 3.0mm for the 500/550. Hoping 2.7 is right for this bike.
Anyone know?
Cheers, Darren
« Reply #33 on: September 13, 2016, 05:45:47 PM »
Great to see so many 550 builds going on. I've been learning a lot by reading through these threads and it's easy to spend time doing so because working on my own project has been great fun.
My project is all about low budget and dependability and the more I look at this bike the more I fall in love with its curves. For 78 this was pretty cool mass production and my plan is to start with a bike that operates and performs like it was intended to originally. It won't be a restoration because I want do some slight modifications with respect to lighting, suspension, brakes and tires and other safety related upgrades, but I'll leave the engine stock (do the top end) and most of the bones (frame, swing arm, electrical, triple, forks, rims and so on) will remain original. I'm old I know what it's like to drive old machines.
Took a look in the tank (there's still gas in it) and it doesn't look bad. Just surface rust. I'll leave it for now, it will be one of the last things I do.
Later, Darren
« Reply #34 on: September 18, 2016, 07:54:17 AM »
Not a lot of progress on the bike itself. I'm now believing more and more in the "make it work then make it pretty" camp and while I have received my bronze swing arm bushings and tapered headset bearings from twowheelfrank I'm holding off taking it all apart until I can get the rest of the parts assembled.
My plan is to take it all apart for painting or plating but when I start to disassemble the swing arm and feel how solid it is (same with front end) I think why take it all apart now for painting/plating when it still seems to be perfectly fine? Why not get the rest of the bike together over the winter and make sure it is running for next summer. Once I have it all together and working well then (next winter I think) I will pull it all apart again for final detailing (detabbing, painting, plating etc).
So I'm busy getting parts, building stands and getting tools. I inherited my fathers old tools and was happy to find his old Vessel impact driver. He was a bodyman starting in the 50's so there are some interesting tools in his tool chest.
Anyway, thanks again to all the contributors for ideas and inspirations,
Cheers, Darren
« Reply #35 on: September 24, 2016, 10:12:26 AM »
Progress is being made, but evidence is scarce. I've been sourcing parts and making a frame stand. Work is busy as the school year is in full swing.
I'm cleaning the other set of PD46C carbs I picked up and this time I'm really trying to preserve their iridescence. I'm really liking the surface quality of a lot of these Honda parts. Many of the fasteners are still that bright zinc and look new and the polished aluminum is my kind of finish: diy cheap sweat equity.
Hope to have the bike on the frame next week and start on the front end.
Cheers, Darren
« Reply #36 on: September 28, 2016, 01:04:34 PM »
Got the bike frame on a stand. Stand is made of left overs from another project and it's not finished.
I'll make another part that will hold up the rear end so I can get the centre stand off. Works ok for getting to the front end for now.
Cheers, Darren
« Reply #37 on: October 04, 2016, 11:27:49 AM »
Update:
So it’s a “run what you brung” kind of project and after some interesting research on this forum I’ve concluded that this bike has a cb450 rear wheel. During my research I came across this thread:
http://forums.sohc4.net/index.php?topic=150358.0
I was originally searching for “play in the sprocket carrier” because I thought there was some play in this wheel. Anyway there is a guy called SoyBoySigh that posted a response that was not entirely enjoyed by all that saw it.
I however was somewhat fascinated and I eventually read the whole thing because he goes on about the different cush drives and some problems with the 550 system. He even goes on postulating about using a cb350 rear wheel because of the simpler design. Well this things got maybe a 450 on it and it looks solid and feels great. Again I’m amazed at how well this bike is preserved after spending something like 26 years outside under a tarp. If this things will work with a 16 / 35 sprocket set up and the right spacers I’m running with it.
So I’m breaking the wheels down to get them clean, inspect and repair if needed. I’ve ordered a bunch of parts from a guy down east. I know there are probably some on here that could supply my needs, but the combination of dollar/peso exchange, shipping costs and customs crap makes it much easier to just buy from a fellow Canuck. He has rebuilt original stator coils, original good quality field coils (all tested and known to work) and many other spare parts that I need. Working out well so far.
I’m also trying out every method I can for doing things just for the hell of it. I’ve melted wax into stuck bolts to loosen them, I’ve sanded chrome with coke and tinfoil, I’ve heated the hell out of stuff and I bought a very fine brass brush that I use on a drill at slow speed to take off oxidization. I plan on trying a few ways to clean and prepare the tank and I was hoping to see an update from sweatshirtolympics on removing stuck studs using alum.
I’m going to give the polished and unfinished thing a go for this year and next winter I will decide the final finish (my hope is that by then it will all be polished, but we’ll see, it is tedious). Pictures below are of the wheels after first clean and starting to remove the oxidation.
I really like the look of these tires and would like to replicate the look. Is this a bad idea? And can tires like this still be found?
Cheers, Darren
« Reply #38 on: October 08, 2016, 06:29:34 PM »
I picked up an extra set of PD46C and have started getting them cleaned up.
It’s apparent that someone was in here before me and I found that one float was badly twisted. The float with the twist is also the one with the bad “shock spring” (for lack of a better term) on the float needle valve. This float looked wrong because this spring is completely depressed inside the needle valve, so it doesn’t push the tab up like the others when they are leaned backwards and the float sits low.
It looks like instead of noticing and fixing the “shock spring” or replacing the needle valve (like I’m doing) the PO tried to bend the float tab….and they did it quite badly, twisting it and bending the tab poorly.
I have been able to straighten up that float and now all the floats look OK but the tabs are off. I’ve been looking at a lot of threads on bending these tabs, and I have yet to find an actual picture that shows exactly how to apply the force to bend the tabs.
Wonder if anyone have a few pictures that show how to bend (pry) the tab up and how to bend it down. I’d like to know what to pry against (if that is the way to do it) because I do not want to twist them up like the PO did.
Later, dj
« Reply #39 on: October 09, 2016, 12:03:27 PM »
I’ve been experimenting with the carb body angle for measuring floats and I’m using a method I saw on Youtube.
I’m very lightly blowing through a tube attached to the fuel inlet (on carb 2) as I slowly rotate the carb rack from a horizontal position. I stop the rotation when the needle valves close and I cannot blow through them anymore (carb 2 has the bad needle valve so I close it with my finger).
I’ve measured the angle at 16 degrees (from horizontal) and the float heights are all around 14.5mm (I’ve straightened some of the floats out and bent some tabs so that all are roughly parallel with the float body).
If I increase the angle to say 22 degrees the floats are still just touching the shock springs but not depressing them yet the measurement is almost 2mm different (all around 12.5 or so).
I’ve read many posts on PD46C float heights and I have seen 12.5mm as much as 14.5mm. With these two measurements I think I will leave them alone for now.
Later, dj
« Reply #40 on: October 14, 2016, 08:56:42 AM »
I received some more parts in the mail (stator, field coil, cover, shifter, gaskets and airbox top).
Winter is here and I’m very glad to have taken this on as a winter project. I’ve had plenty of time to research my moves and I’m really grateful to those that have posted about their experiences.
I am trying to do this low budget, but I’m willing to put in some sweat. Now I’m all about working smarter and not harder and this project is not some kind of “right of passage” (I just want to ride a solid dependable bike) so I’m always looking for a better (and easier) way to do things.
I’ve see beautiful examples of polished aluminum and have read about the effort to get there. Well I like the polished look and found a bunch of ways to go about it, but I decided to try a way from RRR Tool Solutions
http://www.rrrtoolsolutions.com/articles/engine-cases-and-cylinder-finishing/
(I think he is a member here).
This method uses a very fine wire brass wheel at slower speeds to remove oxidation. I use the wheel in a corded variable speed drill on the engine block and made a simple adaptor to run it on the lathe (at about 1200 rpms) to do parts that can be removed. I then use polishing wheels with red and then green abrasive at bench grind speeds (approx. 3500 rpms).
These three pieces have about an hour of effort into each and at this rate I will probably give them some more love and see just how polished I can get them before it becomes a problem.
That’s it for now. Slow and steady, dj
« Reply #41 on: October 20, 2016, 09:20:02 AM »
I've been cleaning and polishing but I wanted to try making some stuff and as this bike is missing some parts I thought I would try some things.
I received a air box scoop and thought it was cool (anyone know what it's from) so I decided to try and make a side cover scoop to help feed it. I want to hammer it out of aluminium eventually and so I made a wooden form from a sketch model. I make forms fat at first and pull some quick styrene positives so that I can check for fit. I need to make some adjustments to this one for fit and then I will reform it until I have it where I want for aluminum forming (a little simpler).
Later, dj
« Reply #42 on: October 21, 2016, 10:14:17 AM »
Modified mock-ups of side cover. Getting close to proper fit.
Shaped aluminium is next.
« Reply #43 on: October 24, 2016, 12:19:05 PM »
Trying out some stuff on the rear wheel.
Built a soda blaster for a grand total of $0 (1/2 kilo of soda for $1.59). Useful for getting inside the spokes to clean the hub. Used diet coke and aluminum on the rims (works OK).
Fine brass brush in the corded drill on the hub and spokes. Sanded spokes with fine paper. Polished brake cover with cloth wheel on the drill (bench grinder is better but I don't have one at home).
This kind of work is never done, as it can always be more polished. Good thing I like the look of oxidized aluminium on old things (what I euphemistically call a "patina"  :P).
slow and steady, dj
« Reply #44 on: November 04, 2016, 10:37:33 AM »
I picked up some Jardine 4 into 2 exhaust and was also able to acquire a new slow jet to replace what looked to be a manufactures defect (it had only 6 emulsion holes instead of eight). I was also able to get a float needle valve, so now I have two complete refurbished stock PD46C carbs.
The guy I bought the exhaust from used it on his 350 and he was selling it because it never fit the 350 right. Anyway I think he squeezed it a bit to get it on his bike and I had to do a bit of wrestling to get it on the 550, but once I got it started it all sucked up very nice. These pipes are effing cool.
I'll get new copper gaskets and polish them up some more.
Coming together slow but sure,
later, dj
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #45 on: November 04, 2016, 10:48:18 AM »
Damn... I need to make myself an engine stand like that. If anything, just to display one of my spare 550 motors.
Coming along, man. Everything looks great!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #46 on: November 04, 2016, 02:17:54 PM »
Hey thanks Joey,
I'm having fun and getting a lot out of this project. I can haul the engine outside when it's nice. I was doing some soda blasting this morning and thought I would get a few shots.
cheers, dj
« Reply #47 on: November 06, 2016, 11:14:37 AM »
Looking at the front brakes. My M.O. is to take things apart, give them an initial clean and inspect them. If they are parts that are out of spec or can be replaced with modern (better) equivalents, like tapered bearings and bronze bushings, then I replace them.
The bike sat outside for probably 25 years and while it is well preserved, brakes are no place to be stingy. This is what the parts look like after an initial clean with very dilute pinesol, rinsed well, blown dry and then cleaned with brake cleaner and blown dry again.
I would love to hear opinions on standard practice for putting an old bike back on the road safely.
cheers, Darren
« Reply #48 on: December 20, 2016, 01:27:18 PM »
Not much to show. I had an unexpected move at the end of November and the bike now lives in a Sea Can.
-20C and colder for a couple of weeks and working on a bike in a frozen sea can is not going to happen. I managed to get the forks cleaned up before things shut down.
Happy holidays everyone!
Darren
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #49 on: December 20, 2016, 02:21:09 PM »
      Looking pretty cool, with this build. Also, interested in the motorcycle stand and the piece that attaches to an engine stand, for the Honda engine. I had seen one that looks like it would basically use an automotive engine stand and the upright part of another one, with some adapting. Always like to check out stands and such that have been thought up and built by folks here.  ;)
Member # 1969
