Author Topic: Cb550k0 rebuild  (Read 21251 times)
Offline Gene
  • Chat enuf you too can be a
Re: Cb550k0 rebuild
« Reply #175 on: December 21, 2016, 09:15:45 PM »
Welcome back. Take your time. I've seen 7-year old threads come back to life here.
*1973 CB750K3 (Bow)
Offline sweatshirtolympics
Re: Cb550k0 rebuild
« Reply #176 on: December 21, 2016, 10:08:21 PM »
Hey thanks Gene, I'm really wanting this done by summer so that I can put the BMW in the garage for frame re-coating, rust removal, etc. SO IT MUST GET DONE!!! haha not a very realistic goal but oh well, I guess we'll see.
Re: Cb550k0 rebuild
« Reply #177 on: December 22, 2016, 02:04:23 AM »
You have your cases separated... so, send the case upper to someone who can do what Cal has suggested.
Have you considerd getting a bottle of Mapp gas and heating the stud  to glowing hot then with a big hammer to help it break the bond.
Clamp a good pair of vice grips on the stud and give it a good slow twist. Release and clamp tighter,  then try to tighten and then reverse direction to remove.
Do this while it is hot.
Repeat the heat cycle and try to get it to start moving.  Soak it with a good penetrant like PB Blaster. Try it again.  See if it will break loose again...
Heat it up again Hit it with PB Blaster when you start heating and see if you can get it to break free.  You really have to get it super hot a few times.  Weld another nut on it better to see if you can get it to yield with a big wrench, worst case the stud breaks and you have to go the route of building it up as Calj has recommended.  Having someone experienced to do the welding and allowing you to work on it after he welds it to get it out.  If they are good they will not damage your cases, I believe there was a case where a welder overspoke his abilities damaging the cases and did not take responsubility for the damage.
Re: Cb550k0 rebuild
« Reply #178 on: February 28, 2017, 01:58:57 PM »
What's up guys! It's your boy again late and drawn out as ever! Ok so, the upper case was sent off to have thoes studs removed, re-tapped n' all that, then both halves were sent off to be glass blasted. But there seems to be some bonded on black #$%* stuck to the inside of the case still. What do you guys recommend I use for the inside of the case to get that crap out!
Slowly but surely, thanks!
Re: Cb550k0 rebuild
« Reply #179 on: February 28, 2017, 02:01:00 PM »
Re: Cb550k0 rebuild
« Reply #180 on: February 28, 2017, 02:01:45 PM »
Oops double post, sorry!
