Author Topic: Cb550k0 rebuild  (Read 25404 times)
Offline sweatshirtolympics
Re: Cb550k0 rebuild
« Reply #50 on: September 06, 2016, 09:34:46 AM »
Haha I hear that! 8)
Re: Cb550k0 rebuild
« Reply #51 on: September 06, 2016, 04:02:44 PM »
Quick question gents, is the hex bolt that holds on the alternator rotor a reverse thread bolt? Same question apples to the hex bolt that holds the points in. Thanks!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Cb550k0 rebuild
« Reply #52 on: September 06, 2016, 04:21:56 PM »
Ya gotta remove the little hex screw before you can remove the big hex nut from the timing advancer.
Then remove points plate, then lastly the advancer itself.
Re: Cb550k0 rebuild
« Reply #53 on: September 06, 2016, 04:55:22 PM »
Perfect thank you gents.
Re: Cb550k0 rebuild
« Reply #54 on: September 06, 2016, 10:23:56 PM »
Shwwweeewww ok sorry this took forever but got the bench up, set up, still tearing the motor down. I'm on removing the cylinder studs and other misc crap. Let's see here. The points and what not are off. Alternator rotor bolt is off but that's all going to take some loud bangin to get that off so I'll wait till tomorrow. Uhhhhh all of the case bolts are out, just trying to figure out how to separate the case. And still waiting on the JIS set to show up so I can remove the oil pump. As always I appreciate the help, let me know if you guys know any secrets around this area. Oh and of course the set up, but ignore the cat photo. That's not mine.  8)
Re: Cb550k0 rebuild
« Reply #55 on: September 06, 2016, 10:24:45 PM »
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #56 on: September 07, 2016, 06:46:32 AM »
Nice progress so far. For the rotor you could use an M16 1.5 bolt. Thread it in tight, heat rotor with propane and whack the bolt with a hammer. Should pop right off.
If you want, have a look at my build thread. In the table of contents there's a link to the rotor removal. Mine seemed much more stubborn than most. Heat might not even be required.
Re: Cb550k0 rebuild
« Reply #57 on: September 07, 2016, 12:42:34 PM »
Aye thanks gents! I'm actually really surprised at how stubborn the oil pump is to remove. I've been able to skimp by this far with removing JIS screws with a Phillips but holy crap those oil pump screws are in there. For the studs how ever I've been doing the whole stack two nuts on top of the threading, tighten em both against each other and rotate the bottom one to wind the stud out but that's proving intense. But from what I understand the studs have to come out before the case comes apart yeah?
Re: Cb550k0 rebuild
« Reply #58 on: September 07, 2016, 12:46:03 PM »
Also holy crap Dave that thread is Tier One af! I'm looking like kindergarten over here!  8)
Re: Cb550k0 rebuild
« Reply #59 on: September 07, 2016, 12:47:09 PM »
Gotcha cal, gunna have to go borrow some tools!
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #60 on: September 07, 2016, 01:42:15 PM »
Are you sure you're turning the screws that old the oil pump to the crank case?  And NOT the screws that hold the cap tight on the pump body?
Cause 6-8# is all you should be up against on most screws.
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #61 on: September 07, 2016, 02:32:59 PM »
Ha, thanks buddy. Just trying to be as organized as I can.
Regarding the oil pump, even with JIS drivers it can be a pain. A nice tool is a manual impact driver (the ones you hit with a hammer). If you get JIS bits for that then you'll be in business. Worst case you can drill the heads off (which are usually the part that's seized) and pull off the oil pump then unthread the length by hand.
If you want to be a bad mother f'er then you can drill them out with left hand bits. I owe Cal for that recommendation. LOVE those things.
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #62 on: September 07, 2016, 02:34:30 PM »
6-8# going in doesn't mean 6-8# coming out ;)
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #63 on: September 07, 2016, 03:38:03 PM »
One of the few "as seen on tv" gadgets I own are the SpeedOut screw removers.
They've saved my arse a few times.
Re: Cb550k0 rebuild
« Reply #64 on: September 07, 2016, 05:08:51 PM »
Actually bomb that's a really good point. I'll try just removing it in general.
But Dave I took your M16x1.50 advice and my local hardware store didn't have it. I'll have to call our House of Honda here and see if he can hook me up with a bolt for the alt rotator removal. Buuuutttt that center punch is a brilliant idea!
Re: Cb550k0 rebuild
« Reply #65 on: September 07, 2016, 05:44:56 PM »
Holy crap I completely forgot I read that last night. Calj +10 for the win, thank you so much.
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #66 on: September 07, 2016, 06:28:57 PM »
I actually am pretty sure it doesn't fit. :(
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #67 on: September 07, 2016, 07:47:54 PM »
Would be quite the trick if it worked.  The spacer would make a convenient slide to tap it out.
Reminds me what I learned of old tallships, all the ropes and riggin on the boat are the very tools ya need to assemble/disassemble the boat!
Y'arr
Re: Cb550k0 rebuild
« Reply #68 on: September 08, 2016, 08:35:21 AM »
Indiana calj
Also I havnt tried yet so that sucks! But wait bomb what? You were a pirate? That's dope!
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #69 on: September 08, 2016, 09:42:53 AM »
Indiana calj
1990's internet music pirate.
Re: Cb550k0 rebuild
« Reply #70 on: September 08, 2016, 11:23:32 AM »
The founding napster pirate.. I can dig it, so does that mean if you downloaded music in bora bora... Does that make you a pirate of the carabian?
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #71 on: September 08, 2016, 11:32:50 AM »
I had really poor taste in music during the nineties :/  tis shameful to speak of
Re: Cb550k0 rebuild
« Reply #72 on: September 08, 2016, 11:56:18 AM »
The 90s had killer music man no worries! Am I showing my age yet pahaha
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #73 on: September 08, 2016, 12:39:00 PM »
Let's not kid ourselves. The 90's also had terrible music, haha.
Offline Gene
  • Chat enuf you too can be a
Re: Cb550k0 rebuild
« Reply #74 on: September 08, 2016, 01:21:34 PM »
1890's had some pretty good tunes . . .
*1973 CB750K3 (Bow)
