Author Topic: Cb550k0 rebuild  (Read 25414 times)
Offline sweatshirtolympics
Re: Cb550k0 rebuild
« Reply #75 on: September 08, 2016, 02:35:09 PM »
Lol w.e calj  :P
But I like how gene swoops in with the 80s save nice one man. Haha but yes the 90s had some terrible tunes like how the disco revamp scene hung around. No disco you can't beat the pop funk.
Offline Gene
  • Chat enuf you too can be a
Re: Cb550k0 rebuild
« Reply #76 on: September 08, 2016, 02:55:27 PM »
Gene mentioned 1890, not 1980. He's an old fart! Must be a huge fan of Victorian parlors  :o ???
One of the bands I play does tunes from 1890's - 1930's.  The fact that I was alive back then only helps my chops ;D.
*1973 CB750K3 (Bow)
Offline Gene
Re: Cb550k0 rebuild
« Reply #77 on: September 08, 2016, 02:59:08 PM »
He died in the late 1700's, but his love children said he was quite a pr!ck.
*1973 CB750K3 (Bow)
Offline Gene
Re: Cb550k0 rebuild
« Reply #78 on: September 08, 2016, 03:11:29 PM »
 Back in a while then . . . I need to pop by the blood bank and make a withdrawal. 8)
*1973 CB750K3 (Bow)
Re: Cb550k0 rebuild
« Reply #79 on: September 08, 2016, 04:45:07 PM »
Lmao and this is what I come back to  8)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Cb550k0 rebuild
« Reply #80 on: September 08, 2016, 07:55:25 PM »
Sorry not sorry
Re: Cb550k0 rebuild
« Reply #81 on: September 10, 2016, 02:51:27 PM »
Not the slightest bit worried man ^^. Glad you guys are enjoying yourselves.
Huuurrrr this case though... Am I missing something or and I just not getting this tiny screw driver between the cases enough or not taping into it enough. She does not want to separate.
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #82 on: September 10, 2016, 03:22:33 PM »
Have you removed every nut n bolt that could be holding the two halves together?
Re: Cb550k0 rebuild
« Reply #83 on: September 10, 2016, 05:12:01 PM »
Lol of course bomb  :o Just didn't know if I was missing something.
Re: Cb550k0 rebuild
« Reply #84 on: September 10, 2016, 07:13:23 PM »
Haha no doubt calj. I'll take me sweet time about it then. Thanks for the nudge. Will report back.  8)
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #85 on: September 10, 2016, 07:57:07 PM »
If I remember correctly, the Clymer manual (not sure which one you have) doesn't actually mention all the bolts needed to split the cases. I believe their count is short by 1. You got the one under the oil pan?
Could always post a picture of the top and bottom cases.
Re: Cb550k0 rebuild
« Reply #86 on: September 11, 2016, 10:38:09 AM »
Exactly Dave the clymer manual is poop for explanation but yeah I'll throw up some photos tonight and will get back to those cases.
Re: Cb550k0 rebuild
« Reply #87 on: September 12, 2016, 06:02:55 PM »
What's up guys! Ok so I've been fighting with the case separation for two days now. I was able to get the cases separated but it seems to be binding on the left side where the alt rotor is. I could have sworn I saw a post on here where a guy had his motor separated but the alt rotor was still attached. What gives?
Re: Cb550k0 rebuild
« Reply #88 on: September 12, 2016, 06:09:53 PM »
Also trying to upload a vid for you... It no work I don't think....
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #89 on: September 12, 2016, 06:26:45 PM »
The rotor doesn't need to be removed to split the cases. Maybe stuck on the locator dowel pins.
Have wooden or plastic wedges you can tap in there?
Re: Cb550k0 rebuild
« Reply #90 on: September 12, 2016, 07:07:35 PM »
Thanks Dave, dunno lemme see what I have around here...
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #91 on: September 12, 2016, 07:19:03 PM »
You'll still want to remove the rotor if you plan on replacing the seal.
+1 fine tapered wedges
Re: Cb550k0 rebuild
« Reply #92 on: September 12, 2016, 07:56:27 PM »
Right so I used these little wood things from my gfs crafting bucket of blocks and wood strips and stuff. They worked brilliantly, I worked back and forth across the front of the motor lifting ever so gingerly with a hand held angled pry bar and rag, and adding one little strip to each side until the cases were split. The seal over there on the left was causing the problem. The one behind the alt rotor. I think..... Thanks for the idea Dave. +10.
Also bomb I agree, those are needed so bad for this issue.
Re: Cb550k0 rebuild
« Reply #93 on: September 12, 2016, 07:59:11 PM »
Z
Re: Cb550k0 rebuild
« Reply #94 on: September 12, 2016, 08:00:05 PM »
Z
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #95 on: September 12, 2016, 08:55:30 PM »
Crikey that motor is covered in sludge aint it?!
Nice use of the 10mm socket
Re: Cb550k0 rebuild
« Reply #96 on: September 12, 2016, 09:44:17 PM »
Yeah bomb! On the outside its covered but the inside looks pretty dang clean. I suppose I'll find out when I measure the wear.  :D
  • Holy Cow! I'm a
Re: Cb550k0 rebuild
« Reply #97 on: September 12, 2016, 09:59:33 PM »
Once you start cleaning you'll realize those parts and the inside of the cases are not actually Black :o
Offline DaveBarbier
Re: Cb550k0 rebuild
« Reply #98 on: September 13, 2016, 04:25:36 AM »
Nice, glad it worked out. Now it WOULD have been better to remove the rotor while the motor was still in the frame, but that's ok. I put my crank in a vice (soft pine and cardboard between the crank and metal jaws) and got it out that way.
Not sure if you've been following AlekStooge's build of his 550 but he's into the cases too right now. Might want to pop over there and have a look-see. I thought he compiled a list of part numbers for all the oil seals needed for the rebuild. I don't like aftermarket seal kits.
Re: Cb550k0 rebuild
« Reply #99 on: September 13, 2016, 06:25:02 AM »
I lold. Black motors matter.
But Dave, is it really necessary at this point to remove the rotor? Oh wait I'd have to remove it to replace the seal yeah? But no I havnt been following his thread at all. Umma scoot over there and check it.
