Author Topic: Early CB 750 Rear brake arm  (Read 1194 times)
Offline major domo
« on: August 23, 2016, 10:26:15 AM »
I'm having trouble getting the rear brake arm back onto the shaft splines on a 1970 CB750. I'm not sure if this is the correct arm, as a photo in John Wyatt's book (page 51) "Original CB750" seems to show an arm that is very straight, while mine  has a  slight curve to it. The one in the book also looks a bit thinner.  If I recall, this arm came off very easily when I dis-assmebled the brake drum many months ago; maybe it was only partially on the splines? The finish is also rough on the inside of the arm, with what appears to be a number/mark cast in it.  I've attached photos of the arm I have.  Any comments welcome!
« Last Edit: August 23, 2016, 11:07:17 AM by major domo »
Re: Early CB 750 Rear brake arm
« Reply #1 on: August 23, 2016, 10:35:10 AM »
brake arms from K0-K5 all reference the same part # 43410-341-700
cant say that yours is incorrect tho  :-\
« Reply #2 on: August 23, 2016, 11:44:08 AM »
It should not push on with your fingers, a light tap with a block of wood and hammer...with cam supported should do it with ease......make sure spline is oriented correctly..
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: August 23, 2016, 11:56:10 AM »
+1
Sometimes a screwdriver in the gap on the end of the arm will open it up and provide some relief. Don't use a big hammer, just tap the screwdriver into the gap with the heel of your hand, it shouldn't take much, then see if it will go into place.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline DaveBarbier
« Reply #4 on: August 23, 2016, 12:21:56 PM »
Obviously make sure splines on both parts are clean. Also, don't try to put the lever on with the bolt in place. :))
Online madmtnmotors
« Reply #5 on: August 23, 2016, 01:12:09 PM »
BTDT!  :o
TAMTF...
Wilbur
Projects:
Offline major domo
« Reply #6 on: August 24, 2016, 09:51:10 AM »
The brake arm will not tap on with a hammer or mallet. I've been told that the brake arm shaft has an area where there are no splines, and that should match up with an area on the brake arm for correct installation. This brake arm shaft has splines all around.
Offline somesuch
« Reply #7 on: August 26, 2016, 06:47:03 AM »
This is what my experience has been....there usually is marker dot on the shaft as well to make the alignment easier
