Author Topic: SOHC4 Family Reunion Aug 15-17 2017 Dolores Colorado  (Read 132494 times)
Re: SOHC4 Family Reunion Aug 15-17 2017 Dolores Colorado
« Reply #725 on: August 06, 2017, 04:06:05 PM »
Which one?  ;)
« Reply #726 on: August 06, 2017, 05:28:12 PM »
I'm buried in work right now and bummed I am going to miss this.
Offline tlbranth
« Reply #727 on: August 06, 2017, 05:41:43 PM »
.......and then you die.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline NewBoots
« Reply #728 on: August 07, 2017, 07:03:28 AM »
My favorite Ann Landers quote. { I never herd off anyone on there death bed say, I wish I had spent more time at the office.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #729 on: August 07, 2017, 02:44:40 PM »
My new (to me) camera (Fuji Finepix S 9480 digital) and GoPro Hero Session were delivered to my buddy's hardware store today. I will pick them up tomorrow and have a few days to familiarize myself with them before I hit the road on Saturday.
The next 3 night in the shop are going to be busy (they are closed Thurs/Fri, so come what may the bike is out of there at the end of the evening Wednesday):
(1) paint front caliper, install new pads, install caliper and bleed
(2) install new chain
(3) finish crimping retaining ring on tach and reinstall on bike
(4) check valves and adjust timing chain tensioner
(4) complete installation of new LED headlight
(5) Replace running light/turn signal bulbs with LED's (including 4 resistors), hook up rear turn signals on bags
(6) install fairing or windshield (whichever is easier)
(7) change oil and filter
(8 ) completely test charging system
Outside the work on the bike, I also need to figure out what actual route I am going to take and where I am going to stay. No pressure.
« Last Edit: August 07, 2017, 09:35:40 PM by Bankerdanny »
Offline CBJoe
« Reply #730 on: August 07, 2017, 03:10:07 PM »
(8) completely test charging system
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #731 on: August 07, 2017, 05:15:58 PM »
Danny, draw a diagonal line from Chicago to Dolores and it will probably come close to Colorado Springs. Drop by and stay over if it works out in your plan.
Do all your necessary stuff first and don't get hung up on the biggies and run outta time and a ride.
See you soon.
Woke up this morning in the low 50's and rain. Be prepared for 3 seasons.
Offline CBJoe
« Reply #732 on: August 07, 2017, 06:14:41 PM »
See you soon.
Had to remind myself of this today and stow a thermal top in my gear
'65 CB77
'66 CM91 (C90'ish)
« Reply #733 on: August 07, 2017, 07:31:39 PM »
Gonna be a shock for me, have not seen rain for 40 days and 40 nights....
I hate the thought. Hope its a least 50 at night thru the trip.
« Reply #734 on: August 07, 2017, 07:52:03 PM »
(1) A functioning front brake is mandatory, but it doesn't need to be pretty. Don't waste valuable shop time waiting for paint to dry.
(2)  8)
(3) A tach isn't really a necessity; move towards the bottom of the list.
(4)/(5) The first part of #4 is good, but if your headlight is working and the turn signals are working, the upgrade to LED isn't really a necessity; bottom of the list.
(7) Higher priority than (6).
(8) Higher priority than (6).
« Reply #735 on: August 07, 2017, 08:35:21 PM »
 I'm leaving early wed morning/tomorrow night. I just did a last minute carb swap to a set of known good 83 carbs. I'll be on the 78gl1000, no 750's ready for the trip except the sandcast and I'm trying to stay under 10,000 miles. I'm headed to Mt, Rushmore /S Dakota first, I got a tip on highway 20 through iowa, I haven't looked it up yet but it involves a good Honda shop stop along the way. Next via Casper Wy, then down the west side of the bumps to Delores.
 I have a cool cantiliever fog light mount, that hangs off the front windjammer bolts. my brother gave me two cool old fog/driving lights. After an afternoon of install and rebuilding they worked for 1.5 minutes. Apparently 6V. Curses.
« Last Edit: August 07, 2017, 08:42:44 PM by Don R »
Offline fatmatt650
  • Part Deux
« Reply #736 on: August 07, 2017, 08:39:10 PM »
My wife's been giving me grief about haphazard planning, you guys are making me feel downright organizized. Finally got my Frankenbeast pretty much together and took her for a little spin today. Still need to install the fairing, work out some fine tuning and odds and ends, register it, finalize my route,  get my gear together, etc., but it's lookin' good!
About two and a half weeks ago -
Yesterday -
Offline Bankerdanny
« Reply #737 on: August 07, 2017, 09:34:58 PM »
Jerry, I am planning a stopover in Denver on Monday. One of my brothers-in-law lives there with his wife along with 2 nieces and 2 grand-nieces.
The chain is installed and tensioned and the calipers painted and rear brake hooked back up. I'll install the caliper along with the new pads and probably a new piston seal tomorrow. The delay really didn't hurt since prepping for paint didn't take much time and the actually painting I did in between other work.
The headlight is test fitted to the shell already. I just need to remove the H4 female plug and replace it with the adapter I got with the light. The other bulbs should be easy too. Already did the tail light and gauge lights.
By the end of the day tomorrow I will have fully functional brakes, full gauges, lights and adjusted valves and cam chain. I have electronic ignition, so no messing with points. I might check the carb synch, but that really depends on time.
« Reply #738 on: August 08, 2017, 12:54:16 AM »
Do not forget to pack your tire gauge , some patches (or plugs if using radials), your chain lube, some rags or paper towels dealing with any mess, few plastic bags.  Some hand cleaner and nitrile or vinyl gloves.
Hot weather and humidity/sweating a lot you can develop a fungal infection easily when riding for long distances.  The Lamasil product for jock itch, terbinafine active ingredient, is very effective to addressing that by killing the fungus.  It is not just a problem that men have to deal with.  Talc or corn starch can help a little but motorcycling shorts or an undergarment that wicks the moisture away helps.  Talc or corn starch can help with any friction.
The lamasil works well but it is not overnight, but it will typically kill any problem within a week using it daily.
Good job on getting the bikes ready everyone and safe travels.
Reminder that a well rested brain from a good night's sleep is one of the best things you can do before the trip.
Stay hydrated  as getting dehydrated will cause you to have trouble focusing and affect your concentration.
Safe travels and post if you have issues on the road with your location.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #739 on: August 08, 2017, 01:34:52 PM »
Instead of "Planes, Trains & Automobiles" it's going to be "Trucks, Trains & Motorcycles".  I booked a roundtrip ride on the Durango to Silverton Narrow Gauge Railroad for Monday.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline Gene
  • Chat enuf you too can be a
« Reply #740 on: August 08, 2017, 01:38:12 PM »
It's not like I'm having broken-down motorcycle dreams or anything. I'm sure everything will be just fine, :|
*1973 CB750K3 (Bow)
« Reply #741 on: August 08, 2017, 02:34:06 PM »
That's fun! Don't drop your phone when you are taking pictures outside the windows  ::) Oh, and watch out for the flying ash coming in the windows.
« Reply #742 on: August 08, 2017, 02:37:54 PM »
If you want to convoy ride south Tuesday morning. I'm right off I-25 exit 151. I MAY need to stick around for a bit before leaving. I have a very important delivery that MAY need to show up that morning. If so I could end up riding the new BMW and have Terry trailer my hot rod leaving ahead of me??
Offline budman
  • 1914X
« Reply #743 on: August 08, 2017, 02:58:23 PM »
There's something about wearing safety glasses on the tickets...
Bud
2021 Indian Scout
Offline Mooshie
« Reply #744 on: August 08, 2017, 06:01:17 PM »
The patches are in, but Photo bucket stopped 3rd party hosting so I am putting up a link to my blog (if you want to see them).  I will be bringing them to the reunion and for those who can't make it I just need the address
https://backdoormotoadventures.wordpress.com/
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline CBJoe
« Reply #745 on: August 08, 2017, 06:44:53 PM »
Looks great! Thanks for getting them made
'65 CB77
'66 CM91 (C90'ish)
« Reply #746 on: August 08, 2017, 06:46:21 PM »
Patch. 8)
Offline Bankerdanny
« Reply #747 on: August 08, 2017, 07:48:25 PM »
That's way cool Lisa. Thanks for doing it.
« Reply #748 on: August 08, 2017, 08:44:29 PM »
 I swapped carbs and the miss was still there, maybe worse. I walked past my brothers tool box and saw a set of new plug caps and sure enough even after testing the old ones and finding all 4 @ 5K ohms, replacing them did the trick. I'll be rolling about 3 am under a full moon on Iowa 20 west.
« Reply #749 on: August 08, 2017, 09:12:46 PM »
The Patches look great!  Can I still get one?
Don
