Author Topic: SOHC4 Family Reunion Aug 15-17 2017 Dolores Colorado  (Read 134960 times)
Offline jgger
Re: SOHC4 Family Reunion Aug 15-17 2017 Dolores Colorado
« Reply #775 on: August 10, 2017, 07:07:37 PM »
Go Frank Go! You can do it! :)
Offline CBJoe
« Reply #776 on: August 10, 2017, 07:41:57 PM »
+1!!!  ;D
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #777 on: August 10, 2017, 07:49:35 PM »
Whew! Just spent over 12 hours working on the bike that I recently declared "pretty much done". Got the fairing and rack on, all the lights working for like, the first time ever, K&N air filter installed, all the intake boots buttoned up tight, adjusted cam chain, sealed up my points cover area in case we hit some rain, and a bunch of other little details. She's been running kinda rough at idle and it's even worse now, making little popping noises. Outside cylinders are reading about a hundred degrees cooler at the bend of the pipes than inside. Compression is an even 130 psi all around and spark seems good, I'm pretty sure I just need to synch the carbs. It's probably been 7 or 8 years since I've done it and I did a half-ass carb rebuild recently (just pulled the bowls and cleaned up the jets) after it sat for the past 5 years. Hopefully that'll do the trick. If not, I'm just gonna wing it cuz she's running great otherwise. Anyone have any advice on what bars to run with a fairing? I've got a Don Vesco Rabid Transit and my "euro" bars hit the fairing at tight turning angles. Fine when riding but you could really hurt your hand while parking (I have visions of cutting my hand in half in a crash). I'm probably going to swap out for some other bars I have that came on a Norton Commando I picked up a few years back but I'm not a big fan of them, too much rise. I think Vesco sold some bars back in the day that were fairly low but with a lot of back sweep. Any suggestions for something similar?
Sweet "F", Fmatt!
I have several sets of "K1" bars, low-rise type, that might fit? (2.5" rise, top-to-top). But, you'd probably have to drop by to try them out, I guess...I'll be 'under the knife' on Tuesday, but if you came by after Wednesday I could show them to you! ;)
Offline CBJoe
« Reply #778 on: August 10, 2017, 08:02:13 PM »
Sweet "F", Fmatt!
Best wishes Mark...wish you could come down and shake hands with us
'65 CB77
'66 CM91 (C90'ish)
Offline tlbranth
« Reply #779 on: August 10, 2017, 08:27:52 PM »
Sweet "F", Fmatt!
I'll second that
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #780 on: August 10, 2017, 09:50:28 PM »
Maybe a few of us will drop in..
« Reply #781 on: August 11, 2017, 10:30:17 AM »
Looking better finally., first pic, damn Beavers.!
Get at it Frank. I need you two maestros rigging up my Webers!!
« Reply #782 on: August 11, 2017, 10:33:01 AM »
All packed. Leaving in the morning. Good luck everyone. Don't let the bastards run you off the road.
Bring warm clothes Terry and everyone. Right now in my part of Colorado at 11:30am it is 59 degrees. Might/could be 90's tomorrow?! Never know. We get 3 seasons weather most of the year. Winter is winter though.
Offline CBJoe
« Reply #783 on: August 11, 2017, 10:56:01 AM »
All packed and hitting the road!
'65 CB77
'66 CM91 (C90'ish)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #784 on: August 11, 2017, 11:24:54 AM »
I have clothes packed in a waterproof bag, but since the bike isn't ready yet, they are just sitting on the floor in my closet. Hopefully though I will be hitting the road myself tomorrow no later than late afternoon.
I printer the 550F wiring diagram to 11x17 paper and have been studying it carefully so I have a specific plan on how to trace the circuits to find what I disconnected or damaged and to fix it.
« Reply #785 on: August 11, 2017, 11:30:31 AM »
Danny have you checked voltage coming out of the ignition switch.  Can hotwire it if that is cause to get replacement switch.
Is neutral switch light coming on
 Or nothing?
Good luck troubleshooting it.
« Reply #786 on: August 11, 2017, 11:32:49 AM »
I wanna come steal Matt's Rabid  Transit faring...my favorite...
Offline vfourfreak
  • Do you think that's wise
« Reply #787 on: August 11, 2017, 11:37:20 AM »
Safe trip you all. Sort of jealous, missing out on all that excitement.
Next year . . .
Kev
Offline Bankerdanny
« Reply #788 on: August 11, 2017, 01:45:58 PM »
 Or nothing?
I have a replacement, I just didn't have easy access to it Wednesday night. I went down and retrieved it from the garage though and it is in my car so I can install it onto the bike tomorrow. That at least is simple, although I am going to transfer the actual switch portion from the new assembly to the old key housing so that my ignition key still works in the seat lock.
« Reply #789 on: August 11, 2017, 01:46:30 PM »
Next year . . .
Kev
Me, too!
Offline Gene
  • Chat enuf you too can be a
« Reply #790 on: August 11, 2017, 02:21:06 PM »
See you there! BTW - that looks crazy comfy compared to what we're bringing ;D
« Last Edit: August 11, 2017, 02:25:35 PM by Gene »
*1973 CB750K3 (Bow)
Offline Gene
« Reply #791 on: August 11, 2017, 02:23:28 PM »
Anyone ever used "fix-a-flat" for a tube? I have a can laying around, it wouldn't be permanent but would it hold well enough to get to a place to repair properly? Just wondering if it's worth it to pack. - So I don't have to it by the side of the road.
Packing the bike up today, leaving tomorrow a.m. Kinda excited.
« Last Edit: August 11, 2017, 02:26:04 PM by Gene »
*1973 CB750K3 (Bow)
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #792 on: August 11, 2017, 02:30:48 PM »
I have on a buddy's bike.  We were riding through Louisiana and his front tire blew out.  Makes a mess.  It comes out the hole in the tube and gets all over the inside of the rim.  He said it wasn't a very stable ride to the motorcycle dealer, which turned out to be not very far away.  We could have called them had we known where we were exactly and they would have picked his bike up and taken in for him.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline Mooshie
« Reply #793 on: August 11, 2017, 02:42:08 PM »
I am bringing a can.  I keep it in my panniers and haven't had to use it yet but it makes me feel better and doesn't take up much room.  I have been told it is a messy operation.  But if I cannot call to get Geico I am happy to have it be messy. I will just pay the shop extra that gets stuck repairing it.
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline Gene
« Reply #794 on: August 11, 2017, 02:44:50 PM »
Thanks both of you. It stays in the pack :)
*1973 CB750K3 (Bow)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #795 on: August 11, 2017, 05:00:32 PM »
Next year . . .
Kev
My sentiments exactly. Ride fast and play hard.
Offline CBJoe
« Reply #796 on: August 11, 2017, 05:35:24 PM »
What? You don't like my custom CX1400?
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #797 on: August 11, 2017, 05:39:32 PM »
My 750 isn't quite road worthy...and I'm not as awesome as Frank and others in regards to rebuilding quickly.
'65 CB77
'66 CM91 (C90'ish)
Offline Gene
« Reply #798 on: August 11, 2017, 06:19:09 PM »
Dammit you know that 750 is ready to go. Just a matter of finding a nice downhill route ;D
*1973 CB750K3 (Bow)
Offline budman
  • 1914X
« Reply #799 on: August 11, 2017, 07:06:11 PM »
Finished trailering up the bike in the dark.  Pulling out at 4am.  Wish I was riding instead.
Bud
2021 Indian Scout
