Author Topic: SOHC4 Family Reunion Aug 15-17 2017 Dolores Colorado  (Read 150661 times)
Offline Mooshie
Re: SOHC4 Family Reunion Aug 15-17 2017 Dolores Colorado
« Reply #1150 on: August 23, 2017, 06:59:51 PM »
I have been using paper towels. Would a tampon work better?  I am adding oil each day so the level is fine and my oil light has yet to come on.
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline Mooshie
« Reply #1151 on: August 23, 2017, 07:01:45 PM »
Rode down the bourbon trail from Indiana today. It smelled like sugar. Ha ha. I had no idea about the white bourbon 🥃. Nuts
1976 CB550F
« Reply #1152 on: August 23, 2017, 07:12:13 PM »
How often do you have to replace the paper towels before they get so saturated they don't do any good? How much oil are you using between fuel stops?
Offline Mooshie
« Reply #1153 on: August 23, 2017, 07:34:20 PM »
I haven't put any in between fuel stops. Only at the end of the day. Yesterday I added about 5 ounces. I am waiting for it to be cooled and then I will check tomorrow for how much I need to add. The towels are saturated pretty quickly. I will use a tampon tomorrow and see how that does
1976 CB550F
« Reply #1154 on: August 23, 2017, 07:35:55 PM »
Well, the paper towels don't have a string for removal. Just depends on the 'flow rate' I guess....
Offline kpier883
  • is quite the
« Reply #1155 on: August 23, 2017, 07:43:22 PM »
Mooshi, My 74 was shedding enough oil at one time that I bought fishing wader pants at a WalMart and cut the leg off and rode with that over my pants.  Changed from synthetic oil back to Delo 15W40 and it slowly quit leaking to the point that I just got an occasional spatter on my pants.
For what it is worth; and I am not trying to start an oil argument.  Might be useful info if you happen to be running synthetic.
Best of Luck !
Kirk
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #1156 on: August 23, 2017, 07:54:22 PM »
Hardly Ableson riders know that motor oil is an excellent leather preservative. ::)
« Reply #1157 on: August 23, 2017, 08:05:44 PM »
Cheap thin rain pants.
Offline mrbreeze
  • Not your average
« Reply #1158 on: August 23, 2017, 08:20:12 PM »
No matter what you use to absorb the oil ...just don't let it get so bad that it dribbles back to the tire. That would be a real bad thing!!
MEMBER # 257
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #1159 on: August 23, 2017, 08:23:45 PM »
Maybe you could tape the tampon to your leg.
Bud
1973 CB750K3 Chopper (in pieces)
« Reply #1160 on: August 23, 2017, 08:26:59 PM »
Maxi-pad might work better taped to the leg? Sorry Lisa. :-X
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #1161 on: August 23, 2017, 08:44:10 PM »
I am presently in Kentucky. This oil leak is driving me batty. Anyone know where Honda man \ Mark lives?  If it is in my path I my contact him and have him fix that head\puck gasket leak and fly back to get it when it is repaired. Or just keep riding and wiping my left leg of flung oil. Otherwise Dash is doing so well.
Hi Lisa,
Try to post a pic of the source of the leak tomorrow.
Would be good to get a better sense of the cause.
Might just need a little attention to the rocker cover bolts or adjuster caps.
« Reply #1162 on: August 23, 2017, 10:29:31 PM »
Naw, We were pretty sureit was pucked up..
Annoying but runnable.
Just jam papervtowel in there with a screwdriver or popsicle stick..
 Just think..... What Would FRANK do ?
 It just dawned on me , I made it there and back.l Success  !
And now I got a running bike...  feels pretty good..
« Reply #1163 on: August 23, 2017, 10:34:23 PM »
Jerry and I were amazed you made it there, given the last minute thrash putting the bike together. :o You did well, little brother. ;D
Offline Mooshie
« Reply #1164 on: August 24, 2017, 04:18:39 AM »
Yup it's that damned pick. Everything else is buttoned up fine. Where is the best place to plug it?  I have been putting the towels on the seam of the heads left side. I assume there isn't some mysterious other place it should go?  And I am making very certain it is not near the tire. So far so good on that front
1976 CB550F
Offline Mooshie
« Reply #1165 on: August 24, 2017, 06:38:41 AM »
Here are pics.
1976 CB550F
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #1166 on: August 24, 2017, 07:20:39 AM »
Here are pics.
Looks like you've been towelling between the head and cylinder.
If that's the source you don't have much to worry about, except the mess.
Oil passage O-ring seal between the head & cylinder is a common fail on the 500/550.
Would need to get really bad to cause issues with the rear tire too. Keep doing what you're doing and have a great time.
Offline Mooshie
« Reply #1167 on: August 24, 2017, 07:37:13 AM »
Thanks jimmy. It really is messy but feel better knowing that is the extent.
1976 CB550F
« Reply #1168 on: August 24, 2017, 07:53:29 AM »
Looks like a lot of oil on the top cylinder head fin? Is the tappet cover we replaced the o-ring on still leaking, or was it really just oil being blown back around the cover? You may need to stuff some paper towel someplace on the top to keep the oil off your leg.
« Reply #1169 on: August 24, 2017, 08:27:38 AM »
Mooshie,
I think you are right about leaking pucks, especially if there is oil out the front of the motor, too.
Its about two hour job to replace those, and not particularly difficult.
Do you have replacements?
« Reply #1170 on: August 24, 2017, 09:11:01 AM »
 Much respect to those that made the trip.
Online seanbarney41
« Reply #1171 on: August 24, 2017, 09:33:01 AM »
Mooshie, I rode for years with leaks that bad.  Hope you like black pants.
« Reply #1172 on: August 24, 2017, 09:39:35 AM »
 Is there any 500/550 experts in her intended path  that can maybe fix it.
 I will toss in some cash via PayPal to help that along if we can organize it.
 It ain't over till the last rider returns to base..
« Last Edit: August 24, 2017, 10:06:02 AM by 754 »
Offline magnum56
« Reply #1173 on: August 24, 2017, 10:04:39 AM »
 It ain't over till the lastvrider returns to base..
That could be a while ... it's seems she is circumventing the globe on this trip !  ;)
Just kidding ...  is my envy showing ?
'74 CB750K
« Reply #1174 on: August 24, 2017, 10:11:42 AM »
You included!
