Author Topic: La Cucaracha; My CB550 Build  (Read 2619 times)
Offline LorenzeTorres
    • Project Pegasus
« on: August 28, 2016, 02:26:26 AM »
Hello All!
My name is Lo, and I present to you La Cucaracha; my 1975 CB550. The name was given by my friends because the seat resembles the back of a Madagascar Cockroach.
This my first motorcycle and I'm slowly learning about it as I replace old or broken parts. A little back story, I purchased La Cucaracha pretty much how it sits today. The first owner (not the one I bought it from) did a majority of the work and the most most recent owner had neglected it. Aside from bringing the carbs in to be rebuilt and the electronic ignition installed, I have done a majority of the work myself which includes, wiring the digital cluster, installing new coils, replacing the whole front brake system (because the last one was seized up from the brake fluid crystalizing in the lines), and some little stuff here and there.
The direction of this build is to go for a resto-mod look. The bike has a brat style to it and I want to add a little modern street bike flare. I commute about 180 miles on it a week and I ride the canyons to relieve stress on my weekends.
The current job I'm tackling is getting the rear-end squared away with the wide tire. I know that many people have suggested against it because it ruins handling but I just can't shake how good it looks. I recently purchased the 17x4.5 rear kit from cognitomoto and I'm trying to figure out how to accommodate the rear sprocket spacer. I'm currently not running the rear spacer because I do not have enough thread to bolt it on the rear hub but I am running the front offset sprocket. The chain is straight but my issue is that the outer edge of the tire hits the chain by a little bit. Can anyone shed light on this issue.
The next thing I anticipate doing is dropping the rims size from 19" to 18x2.5 in the front. I want to keep the stock forks and my thinking is that dropping an inch in the front will compensate for the changes made in the rear and bring back the regular suspension geometry. Being aware that the bike is not setup for optimal handling with the wide rear, I'm trying to figure out a solution to minimizing the negative effects without having to run a GSX-R front fork.
With that said, I hope you guys and gals enjoy. I plan on documenting and sharing any changes I make to La Cucaracha.
« Last Edit: August 28, 2016, 02:43:39 AM by LorenzeTorres »
Offline Lostboy Steve
Re: La Cucaracha; My CB550 Build
« Reply #1 on: August 28, 2016, 03:52:48 AM »
Nice bike! I'm not particularly fond of the wide tire, mostly because it takes power to turn it. To each their own though. The seat is very cool. Welcome to sohc4.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
    • Project Pegasus
« Reply #2 on: August 29, 2016, 10:44:36 PM »
Hey Calj737,
Thanks for your input!
The rear sprocket was not dished. I'll most likely have to replace the bolts with longer ones.
I'm running a 160 width (as recommended by Cognito Moto) on the rear and I believe the spacer for the rear sprocket is supposed to fix that.
I'm looking to purchase to rearsets for the bike once I iron out the funny business in the rear end.
I'll keep you posted with the progress!
    • Project Pegasus
« Reply #3 on: August 29, 2016, 10:45:44 PM »
So I've heard :(
and thanks for the compliment!
