Author Topic: Headlight went dim...  (Read 603 times)
Offline Holshot
« on: August 29, 2016, 05:16:29 PM »
Hey guys,
I took my '74 CB750 out last night and after about an hour of cruising the strip/beach and on my way home the headlight went dim. It was running and working fine and right before I turned onto my street the light output went to about half. I originally thought I had hit the switch to the low beam accidentally but after switching back and forth a few times between the high and low setting the light is still extremely dim.
Any ideas on what to look for or where to start on my search to get the headlight back up to 100%...? Just FYI, new battery and she is holding a charge and sits at 13v+ at idle and goes up with revs. I don't think it's a charging issue. Thanks in advance!
1974 CB750K
Offline b52bombardier1
Re: Headlight went dim...
« Reply #1 on: August 29, 2016, 07:50:35 PM »
My guess is a dirty or nearly broken connector.  Maybe something wrong in the hi / lo beam switch.  Basically, you have a high resistance somewhere that is limiting current to the headlight and you will likely find that it has gotten hot there and melted it's surroundings.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Online Don R
« Reply #2 on: August 29, 2016, 08:09:26 PM »
 Check the ground wire too.
