Author Topic: Cam Chain Tensioner  (Read 1474 times)
Offline lash
Cam Chain Tensioner
« on: September 01, 2016, 05:14:54 PM »
I ordered a complete cam chain tensioner from Yamiya for my 69 K0 and the part numbers say that everything is correct, but the roller is much bigger. Attached pic shows the new one on the left and the one that came out of the engine on the right. Is this a problem?
« Last Edit: September 01, 2016, 05:17:12 PM by lash »
Re: Cam Chain Tensioner
« Reply #1 on: September 01, 2016, 06:46:48 PM »
 Don't have the answer but seeing if I am going to learn something new about early verses newer etc..  That is a big size difference, any sign the old one had been ground down from use or lots of debris in the oil pan ? Sure an early guru will fill us in.
Offline lash
« Reply #2 on: September 01, 2016, 06:54:01 PM »
The old one doesnt look that bad but it is definately smaller. I  have been looking at the Honda shop manual -old green one; and on page 30 it shows the tensioner with the big wheel, so now I am really confused. I dont know the history of the engine so maybe the small one was a PO mistake?
« Reply #3 on: September 01, 2016, 06:56:47 PM »
It does look odd. Think the engine had been opened up before ?
Offline lash
« Reply #4 on: September 01, 2016, 07:21:01 PM »
I cant tell, it sat outside for so long it was a real mess and I am no expert at any of this. This is my first engine rebuild so its all new to me.
Offline eigenvector
« Reply #5 on: September 01, 2016, 07:24:37 PM »
I just looks ground down to me.
The grooves are in the right place, the central hole the same diameter.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #6 on: September 01, 2016, 07:52:17 PM »
looks like a well-worn tensioner roller  :o
Offline kmb69
« Reply #7 on: September 01, 2016, 07:54:13 PM »
.....Is this a problem?
The problem was in your engine. Your original parts are both wasted. Something pretty bad going on there.
Never seen rollers that worn. As bad as those look, I would be suspect of everything in that motor.
Especially, the cam chain, camshaft sprocket, and possibly the cam sprocket on the crankshaft.
For sure the oil pump and all oil galleys need to be inspected/repaired/replaced.
Offline lash
« Reply #8 on: September 01, 2016, 08:15:12 PM »
Engine was completely disassembled. Bored out, new valves, all chains, seals.
