.....Is this a problem?
The problem was in your engine. Your original parts are both wasted. Something pretty bad going on there.
Never seen rollers that worn. As bad as those look, I would be suspect of everything in that motor.
Especially, the cam chain, camshaft sprocket, and possibly the cam sprocket on the crankshaft.
For sure the oil pump and all oil galleys need to be inspected/repaired/replaced.
