In had no charging at all and the checks indicated a bad rectifier. Replaced that and now I have excellent charging ( 14.2 at the battery ) but only when I shut off the switch that kills the headlight. Turn the headlight back on and it drops to now higher than 12.7 no matter how fast I rev the engine. Turn the light off and she jumps right back up.
Is this the normal way the charging system works?? Bike is a 74 CB 550 Four. Is there a wire hooked wrong at the voltage regulator maybe?? Its wired the way it was when i got the bike so maybe a PO swapped a wire around down there?? In any case, I want to get it to charge at the 14.2 with the headlight on too. Whats the fix here?
I have done the service inspections per the manual here starting on page 93. I note it has daylight and night time charging values...please explain this to me. Shouldnt I be getting at least 13.8 at idle with the headlight on or off?
Im confused I guess on how the system works as far as kicking in when it senses the batterys stored voltages.
Maybe its working right..I just dont know 100%. The battery was 100% charged because i just took it off the charger before trying out the new rectifier.
Service manual here.........
http://www.dotheton.com/downloads/CB500-550_Manual.pdf
