Author Topic: Which direction the the pins that hold the floats in come out and go in?  (Read 914 times)
Offline RainCityRider
  • BRAAAP!
  • instagram @raincityrider76
I know the pins press out in one direction. But I forget which way they go..... ;D
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
Re: Which direction the the pins that hold the floats in come out and go in?
« Reply #1 on: September 05, 2016, 03:36:46 AM »
Usually work on earlier 750's etc where the float pins go in both directions. 78 different ?
Offline b52bombardier1
« Reply #2 on: September 05, 2016, 05:40:14 AM »
It's either direction for the float pins on my carbs.  My bet is the end of the brass pin has gotten peened out by somebody thus fattening it to the point that it won't fit.
Rick
1972 Candy Yellow CL100 K2
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: September 05, 2016, 08:06:40 AM »
To the side  ;D
« Reply #4 on: September 05, 2016, 09:00:53 AM »
On my K8, it is either way. Sometimes they need some lube and gentle taps with something thin like a punch or a thin nail with the point ground flat. Once you get the end out enough to grab the tip a needle nose and a twisting action should pull it out.
« Last Edit: September 05, 2016, 09:02:43 AM by BobbyR »
  • BRAAAP!
« Reply #5 on: September 05, 2016, 12:08:56 PM »
They went in way easier than they came out. Almost loose.
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
« Reply #6 on: September 06, 2016, 01:30:03 PM »
 Gas varnish will sieze them, use some carb cleaner on them. Be careful too, the posts sometimes break off if you get too rough.
« Reply #7 on: September 06, 2016, 01:49:35 PM »
They should slip in with your fingers, eyeball them to center them, then the floatbowl should prevent end play. Then in use the gas varnish will stiffen them up.
 Keep in mind too if there is a burr or flare, going to need pressure to install...not so good.roll the end thru a finger and thumb with light pressure on it..should feel if uts flared or burred.. The end going in should be smooth and round.
  • BRAAAP!
« Reply #8 on: September 08, 2016, 12:54:23 AM »
Sweet guys, Thanks!
78 CB750K
78 CB750K
78 CB750K
99 ZRX 1100
