Author Topic: Oil breather end  (Read 1273 times)
Offline _mark
Oil breather end
« on: September 06, 2016, 02:22:47 AM »
Hi guys, my bike (four 750 k1) is leaking oil from chain and spreading it all over the back of the bike in great quantity.
After investigations (i checked also the automatic oil greaser), I found that probably the reason is the breather (is this the correct name?) of the engine head cover.
Where is advisable to put the end of this?
Because the chain could be a good place since the leake is little, but if I make an elongation of the pipe, this will lead to go the wheel and that is not nice.
Is it normal that the breather is going to leak a lot with hot temperatures? my oil is Motul 5100 15w50 4T
« Last Edit: September 06, 2016, 02:25:18 AM by _mark »
Re: Oil breather end
« Reply #1 on: September 06, 2016, 07:01:01 AM »
It is not oil.  It is crank case vapor condensate, and it should drain on the right side of your bike, near the swing-arm pivot.
Offline _mark
« Reply #2 on: September 06, 2016, 12:36:13 PM »
Thanks. Is there a rule for the side and position of all drains? Thanks.
« Reply #3 on: September 06, 2016, 12:42:34 PM »
Most all are on the right side, including the carb overflows...
The 550 i just finished had a small wire holder to keep all tubes off to the right side of the tire...
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: September 06, 2016, 01:48:41 PM »
If you have not plugged the auto chain oiler that is probably the bigger source of your oil leak.
Offline _mark
« Reply #5 on: September 06, 2016, 07:17:04 PM »
As I wrote in the first message, I plugged it.
