Author Topic: Competition Tachometer  (Read 4395 times)
Offline Old Scrambler
« on: September 08, 2016, 02:31:49 PM »
I'm looking for TACH recommendations to fit on my Classic Bonneville Racer ................electronic with sweep-dial vs mechanical .............smallish........about 3-inch diameter. Shift-lights or adjustable red-lines are secondary to an accurate indicator.
I've tried original units and cheap digital with failures when it counted.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Re: Competition Tachometer
« Reply #1 on: September 08, 2016, 02:59:07 PM »
Good luck Dennis.  ;)
Offline turboguzzi
« Reply #2 on: September 08, 2016, 03:34:48 PM »
most classic racers around here use either Pitsch Kröber or Scitsu counters, they are period correct and super reliable. me, being the Dr. cheapo i am, i just recycle GSXR internals and fit them in some old Veglia housing from a guzzi or benelli :)
« Reply #3 on: September 08, 2016, 06:37:46 PM »
Interesting so far...................thanks, guys 8)  I'd like to stay with a plug-wire pickup to avoid a tach-problem affecting the coils.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline teebee67
« Reply #4 on: September 09, 2016, 12:33:56 AM »
I have used Scitsu tachometers for many years on many bikes and have one fitted to my current CR750 replica. They pick up from the plug lead(s) and are very reliable and look period. Also their after sales (in the UK) is superb. I have used many other tachometers as well but the Scitsu's are very good and take no power from the bike.
I'm only old on the outside.
Offline simon#42
  • liverpool
« Reply #5 on: September 09, 2016, 03:44:13 AM »
yes the scitsu tacho's are very good , they are accurate and very light . aprilia fitted them to there production racers for years.
personally i prepare krober's , only because i think they look better !
« Reply #6 on: September 09, 2016, 06:27:41 AM »
I am sure Sam Green used one of them too. You tape it to the plug lead.
« Reply #7 on: September 09, 2016, 07:53:24 AM »
Lots of Scitsu here too. I love my Pitsch Krober, tough as a boiled owl, and the needle reads steady, great tach. It reads from coil however.
« Last Edit: September 09, 2016, 10:32:45 AM by bwaller »
« Reply #8 on: September 09, 2016, 05:47:31 PM »
Thanks, guys..............now you teaching me something............boy, do I have a lot to learn ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline simon#42
  • liverpool
« Reply #9 on: September 10, 2016, 01:59:53 AM »
we all have plenty to learn , when we share stuff we all get a bit smarter !
Offline teebee67
« Reply #10 on: September 10, 2016, 04:11:52 AM »
Ditto Simon.
Offline vfourfreak
  • Do you think that's wise
« Reply #11 on: September 10, 2016, 05:55:37 AM »
I need to boil an owl to see how tough that is. Never heard of that before.
I learn a lot culturally here.
Kev
Offline simon#42
  • liverpool
« Reply #12 on: September 10, 2016, 06:38:42 AM »
have we finally found something the french dont eat .
Offline Rookster
« Reply #13 on: September 11, 2016, 07:33:16 PM »
Which Scitsu unit would work on the CB750?  I'm assuming its the Blue one which fires each coil 1 time per crank revolution. Same question for the Krober? Since the Krober gets the signal from one coil is it the 1 fire per revolution version?  Any help is appreciated.
Thanks
Scott
Offline simon#42
  • liverpool
« Reply #14 on: September 12, 2016, 01:07:48 AM »
double check with the manufacturers web sites but i think it is blue for the scitsu and an LZ23 krober
Offline lordmoonpie
    • Moonpie
« Reply #15 on: September 13, 2016, 11:29:09 AM »
Scitsu are great and used to be down the road from my old house in Sheffield! They are super helpful so tell them what you want Dennis and you'll get the right unit. They also service them if y should need it in the future like when you leave the battery plug out all winter and kill the battery....DOH!
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #16 on: September 13, 2016, 11:54:39 AM »
I have contacted Scitsu in the UK............very helpful........and currently lower priced than the US distributor. I plan to have a spare battery because of the harsh-conditions of my chosen sport, as well as the limited actual use ;)  Thanks for all of the suggestions and info :) :) :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
