Author Topic: Carb Sync Tool - 5 MM or 6 MM Brass Tubes??  (Read 1664 times)
Offline b52bombardier1
« on: September 09, 2016, 04:24:38 AM »
Hello,
  I have not done a carb sync on my 72 CB500 bike and I'm finally getting around to buying the sync tool.  But do my carbs need the 5 millimeter brass tubes or the 6 millimeter type to connect the synchronizers?
  The search function does not work here and the Carb FAQ makes no mention either way.  And the downloadable shop manual doesn't even have a section within the carb area about synchronization. So rather than guess and possibly waste a few bucks plus the time, somebody around here will know the answer.
Many thanks,
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Re: Carb Sync Tool - 5 MM or 6 MM Brass Tubes??
« Reply #1 on: September 09, 2016, 04:37:21 AM »
Take out the screw and measure it.  750 has M5 tubes, yours probably too.
« Reply #2 on: September 09, 2016, 04:48:55 AM »
I'm an idiot.  I have one of those nut / bolt thread size and pitch things in my garage for metric and English nuts and bolts.  I will use it to answer this question and thank you for reminding me . . .
Rick
« Reply #3 on: September 09, 2016, 04:57:52 AM »
And a drum roll please, maestro . . . as you predicted . . . it's M5 x .8.  Thank you very much and I can now order the correct tubes.  Now if I only had a brain . . . . ????
Rick
Offline Thekramer666
« Reply #4 on: September 09, 2016, 05:13:49 AM »
Future reference
I just looked up the screw u take out and then I knew
Honda cycle schematics
http://www.cmsnl.com
Please check your messages & follow up on your posts!!
76' CB550F SS
« Reply #5 on: September 09, 2016, 05:19:38 AM »
Ah yes, another excellent reference. Thank you.  It's been a long week . . .
Rick
« Reply #6 on: September 09, 2016, 05:34:45 AM »
Rick
Everybody has senior moments:)
« Reply #7 on: September 10, 2016, 05:21:03 AM »
I wish I was 30.   I'm as old as my tongue and a little older than my teeth . . . . 57.
Rick
