Author Topic: Engine bolt sets/kits?  (Read 5962 times)
Offline rocs
« on: September 11, 2016, 06:51:12 PM »
Where is a good place to buy engine bolt kits? I want to replace all the bolts on the engine cases etc.
Hex vs allen vs phillips? Any preference?
I understand anti seize is an absolute must if going with stainless.
1975 CB550k's
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: Engine bolt sets/kits?
« Reply #2 on: September 11, 2016, 11:27:01 PM »
Stainlesscycle.com is excellent, but it won't be every engine bolt, just the covers. 4i to1.com is also a good bet.
I have a motorcycle problem.
Offline calj737
  • I refuse...
« Reply #3 on: September 12, 2016, 04:21:57 AM »
You will struggle to find a few specific case bolts (for the 500/550 at least) that are 155mm in length. Most currently available stainless hex or socket caps stop at 100mm over the counter. I use www.allensfasteners.com and buy ARP in either hex or 12-pt. They cost more, but they are by far the strongest (not really needed on side covers, etc) and widely available bolts out there.
Offline rocs
« Reply #4 on: September 12, 2016, 05:33:48 AM »
http://4into1.com/stainless-steel-allen-bolt-set-honda-cb550k-1977-1978/
https://www.boltdepot.com/
http://www.ebay.com/itm/HONDA-1968-1978-SOHC-CB750F-CB750K-CHOPPER-POLISHED-STAINLESS-ENGINE-BOLT-KIT-/310153665220?hash=item4836995ac4:m:mAXevjwFsbfnJFGtqDZ3_Eg&vxp=mtr&rmvSB=true
http://www.ebay.com/itm/MOTORCYCLE-BOLT-KIT-STAINLESS-STEEL-HONDA-CB750-FOUR-SOHC-ENGINE-MOUNTS-/361481535131?hash=item5429fa7e9b:g:EbgAAOSwHPlWeGEP&vxp=mtr&rmvSB=true
Thanks! I saw these kits on ebay but wasn't sure which was the best. I see some come with just the bolts and some include washers. Not sure which is the preferred set on the boards :)
The last link you included is the actual axle bolts for mounting the engine. I haven't seen these around yet!  Does anyone have a US supplier for these?
1975 CB550k's
Offline rocs
« Reply #5 on: September 12, 2016, 05:35:17 AM »
Thanks for the site Cal!
I need to replace the front engine mount bolts on my engine when I get ready for install. The bolts that attach the engine to the frame using the two brackets. Does anyone have a source for these bolts?
Edit: just did a search for the front mount bolts are they are M10x80. Ironically it was a post by you Cal
« Last Edit: September 12, 2016, 06:18:28 AM by rocs »
1975 CB550k's
Offline calj737
  • I refuse...
« Reply #6 on: September 12, 2016, 06:38:29 AM »
Allensfasteners has 10x80 in ARP hex heads. In stainless and black oxide, but not a fan of black oxide for external usage on engines. You can get them in both 1.25 and 1.5 pitch too  :)
You asked about flange head or hex with washers. Metric flange heads have a slightly wider dimension than JIS hex with washers. In the end, the torque value is low enough that I don't believe it makes an iota of difference which you use.
Offline drumstyx
« Reply #7 on: September 12, 2016, 07:05:00 AM »
I have a stainless engine bolt kit I got on eBay.. I haven't used it yet, but I've heard stainless bolts are much weaker than regular bolts...is that true?
Offline calj737
  • I refuse...
« Reply #8 on: September 12, 2016, 08:00:01 AM »
All depends upon what grade of stainless and what grade of steel you compare. With respect to ARPs, their tensile strength is 175,000-190,000. Grade 8 is about 150,000. Most of the cover bolts are probably Grade 5 at best, some mounts are surely 8s.
Offline colvinry
« Reply #9 on: September 13, 2016, 04:37:43 PM »
What we need to do is put together a complete bolt size list and then people can order what they need or get the whole kit from McMaster or their favorite fastener shop.
Offline NobleHops
« Reply #10 on: September 13, 2016, 05:12:59 PM »
Great idea man. Dig in! :-)
Offline rocs
« Reply #11 on: September 14, 2016, 07:27:19 AM »
After doing some searching throughout the forums, I ended up buying a complete kit from http://www.stainlesscycle.com. I also purchased the front engine mount bolts, lock washers and nuts as well since they tend to be harder to find.
It may be cheaper to purchase these kits rather than assembling a kit on our own.
1975 CB550k's
Offline itsahonda4
    • www.wfomodels.com
« Reply #12 on: September 14, 2016, 07:37:25 AM »
I think the point we are trying to get to is to be able to buy a set of NOS type bolts and screws is it not? I personally have no interest whatsoever in allen bolts...
Be that as it may, I have a couple of spare engines and Im going to strip one and do a simple exercise on what the cost would be to get them nickel plated and then offer an exchange service, or alternatively, go to a supplier and ask for a package of all the enclosed bolts in one bag....
Is that the direction some people would like me to go?
But I will only do early SOHC's up till about 77 when those hondamatic things came out....
Al
Offline slikwilli420
  • Master of Disaster
« Reply #13 on: September 14, 2016, 08:47:22 AM »
http://www.mcmaster.com/#machine-screws/=145z1ay
That is your best and cheapest bet I have found so far for JIS fasteners. Come in SS if you want as well as Zinc.
Offline Alan F.
« Reply #14 on: September 14, 2016, 08:51:32 AM »
Good quality kits made by a member of sohc4 for over a decade.
http://www.metrocast.net/~spillane/index_004.htm
