Author Topic: Who regularly drives over 80mph?  (Read 5384 times)
Offline SDmtnbkr
« on: September 16, 2016, 07:49:19 PM »
i live in San Diego, the land of big freeways, and mostly use my bike as a commuter, so that means that pretty much every time I ride I'm up around 80-90mph. At about 90 mph the speedometer starts bouncing around pretty good!
I'm still on stock bars and I'm thinking I need to switch to clip-ons to get me in a better position against the wind. I was just wondering how many other people are high speed commuting with their 40yo bikes and how your bikes are setup?
Re: Who regularly drives over 80mph?
« Reply #1 on: September 16, 2016, 08:22:00 PM »
Me! Regularly. :)
For bouncy speedo that might not be inside the gauge: look for a worn speedo cable, especially where it comes out of the drive box at the axle. They like to wear there, particularly when they were incorrectly set up to have too sharp an angle there. It is supposed to come out parallel to the fender stay, then curve gently upward to the frame and steering tree, no bends beyond that. Many times this angle is set up too sharp, then the cable wears out inside the fitting.
Also, take the speedo drive off the wheel and either disassemble and re-lube it with new grease, or at least put a little oil in there to soften up the old grease inside. Make sure the flat plate that drives the gearbox is also centered on the front wheel: sometimes these get assembled off-center a little bit, which makes the cable vibrate, which affects the speedo....
I ride behind a Vetter. Many don't like them, but I won't ride without one after 40+ years with it. At 105 MPH the windshield starts to fold over a little bit, but unlike the early ones (before the 1974 DOT-approved versions) it doesn't come back far enough to touch me in the nose! :)  And in crosswinds, rain, snow, sleet, hail, or bird-bug attacks, it is my best friend. I just rode thru all but the bird-attack part of this last Saturday, going up to the top of Mt. Evans. :D
I recently swapped the countersprocket to 19T instead of the 18T that has long been there. It makes 5th gear into overdrive, with 4th acting much like 5th used to.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: September 16, 2016, 08:26:15 PM »
I've been known to ton up from time to time.
Supersport bars arent as low as clip ons, but they work for some decent wfo sprinting.
Just don't go into the turns too hot now.
Offline SDmtnbkr
« Reply #3 on: September 16, 2016, 10:46:19 PM »
Me! Regularly. :)
Dang 105!!  8) 8)  Yeah, idk if that would be as fun without any kind of fairing. Thanks for the tips, I'll definitely look into all those things. I'm really interested in this rear sprocket you speak of... so where did you really see the difference, only in the extreme high end, or do you enjoy 5th now more overall? Also, what bars do you use?
My bike pulls really hard up to 90 with plenty of power left to push it further, I've just not elected to push it past that as the roads really suck in SD and with stock bars I get a ton of force applied on my body. Our roads are bumpy and rutted all over, so the bike kind of feels like it likes to wonder at that speed and doesn't feel completely planted.
« Reply #4 on: September 16, 2016, 11:14:44 PM »
Like many I had a nervous speedometer. Many years ago I took the speedometer cable apart and lubed it with lithium grease. Ever since stable even at top speed.
Offline flatlander
« Reply #5 on: September 17, 2016, 12:04:55 AM »
i need to try that. i have a new cable but the needle sometimes goes bouncy. thought it may have something to do with the internals of the speedo but will try the lithium grease first.
i regularly go at 150-160kph on some stretches on highway and use euro style bars (similar to those that came stock with the 550 european models). they work fine for a while if you tuck in a bit. if you want to go for longer periods at such speeds an unfaired bike is not the thing...
Offline Bailgang
  • Scott
  • Indiana
« Reply #6 on: September 17, 2016, 02:28:11 AM »
My F2 still has it's factory bar on it while my kids previous K3 had the euro/superbike bar and in my opinion the euro bar was much more comfortable at interstate speed.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline dhall57
« Reply #7 on: September 17, 2016, 03:57:56 AM »
Im generally a law abiding citizen. But every now and then on a long country road I will get a wild hair and a need for speed even at almost 60 years old. Here is my tachs. So in these cases I am driving over 80mph ;D
« Last Edit: September 17, 2016, 04:01:44 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Sigop
« Reply #8 on: September 17, 2016, 05:24:15 AM »
Is that taken with one hand on phone/camera and only one hand on the bars?
CB750 K3  Original Owner and Operator
Offline Johnie
« Reply #9 on: September 17, 2016, 06:50:31 AM »
Hall...I knew you had that wild side :) When I sold the K3 project last June I wanted to have a video of it while I rode. Took the iPhone and put it under my helmet behind the shield. Worked pretty slick...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #10 on: September 17, 2016, 10:36:31 AM »
Hey dhall - every time I see those pics I think "he needs to correctly route his cables"!!
They should not block the clocks
Offline jonda500
« Reply #11 on: September 17, 2016, 06:45:37 PM »
I do. I like the lower stock style bars and have 400-4 bars on one of my 500s. Around town I can sit up straight, but out on the open road I lean forward to the balance point between getting blown back and not getting held up when leaning too far forward.
John
A starter clutch thread:
Offline thirsty 1
« Reply #12 on: September 17, 2016, 07:54:45 PM »
I gotta tuk on the little 400 but I can hit 95 :) It's pinned!
Offline bender01
« Reply #13 on: September 17, 2016, 10:02:14 PM »
Not regularly but when I do its on a long Carolina pine lined rd! I start to listen to the sounds an think about how much my (Me)chanic drinks late at night working on my bikes! Slows me right back down.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline dhall57
« Reply #14 on: September 17, 2016, 11:58:58 PM »
  You weren't suppose to notice that. What a eye for detail ;D When I first posted these pics just wanted to show how easy these 750's would do the ton with plenty of speedo and tach left. Should of known if anyone here was going to say anything it would be you Stev-o. What are friends for right ;). Been meaning to change the cables or the bars back to OE since I've had the KO but just never have. Not sure what the bars are maybe superbike(very low rise) but of course they make the cables much to long and the reason for the crazy routing. Been that way for so long Ive got use to it and really don't pay any attention to it.
« Last Edit: September 18, 2016, 04:06:27 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline SDmtnbkr
« Reply #15 on: September 18, 2016, 01:15:32 AM »
Well I'm my own mechanic, and I definitely have a beer or two while wrenching, so when the thought pops into my mind around 95mph I just smile and hope I didn't miss a torque haha
Offline flatlander
« Reply #16 on: September 18, 2016, 03:58:48 AM »
i don't drink while i'm wrenching or while riding the bike. after wrenching or riding... different story  ;D
Offline Lostboy Steve
« Reply #17 on: September 18, 2016, 06:07:04 AM »
I ride my 550 at about 80~ on the highway. Even then people are almost rear ending me.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline david 750f
  • 1976 CB750F
« Reply #18 on: September 18, 2016, 06:10:18 AM »
SDmtnbkr, try the European/Superbike bars. I cruise at 80ish and higher, when traffic allows  ;) ;)
David Silver can get the Honda pre-drilled factory low bars if you have the correct part number.
1976 CB 750F
    • http://forums.sohc4.net/index.php?PHPSESSID=gv4rcouges9m15pjd6eu9alhn4&/topic,60973.0.html
« Reply #19 on: September 18, 2016, 08:37:51 AM »
yes thomaselli euro bars is perfekt..clip on"s is overkill..
i thorth i often drove plus 100 ..but faund the spedo is a bit positive..+ 15 kmt..so normaly just do the ton..but thats fine..dont need to go farster..
« Last Edit: September 18, 2016, 08:40:20 AM by strynboen »
« Reply #20 on: September 18, 2016, 08:33:24 PM »
 Not regularly but my Sandcast will go 95 indicated for sure. I wanted the ton but there was a T ahead and I was on the wrong end of it. For the long ride to Sturgis.
Offline Desert-SOHC
  • It's old
« Reply #21 on: September 18, 2016, 09:07:51 PM »
80+ seems to be the norm on my K8, but I live in socal and the cages like to run up your azz if your any slower, and around here 80 puts you in the slow lane.  I regularly am around 90 or so on my speedo to stay with traffic but I'm pretty sure its slow by at least 5mph.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
  • Holy Cow! I'm a
« Reply #22 on: September 18, 2016, 09:13:45 PM »
Always best if you can outrun danger.
Offline koendd
« Reply #23 on: September 19, 2016, 04:22:52 AM »
yep, me too when I commute with the CB. Recently got a 1984 GPZ900r to commute so the CB is retired now.
Once did 120Mph on GPS with my K2, that's about top speed I think...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #24 on: September 19, 2016, 07:45:43 AM »
I do.  Red feels very comfortable between 80 - 90mph.
