Author Topic: Oil drop from K0 alternator cover  (Read 1259 times)
Offline pyropupx36
« on: September 18, 2016, 02:19:12 PM »
Hi All, I have a persistent drip of oil coming from my alternator cover (the very edge as I am always on the side stand) on my 1970 K0. The engine was supposedly rebuilt when I bought it but I do not have any firsthand knowledge if every oil seal was replaced, etc. I fully intend to remove both the alternator cover and the transmission cover on the next oil change; hopefully that will help me narrow in on the exact location of the leak. I'm afraid right now it's the crankshaft oil seal behind the rotor. Sometimes I think it might be coming from the heads of one of the two main bearing case bolts immediately inboard of the alternator cover, but still hard to tell.
Any advice or experience with this location for a dripping alternator cover edge would be appreciated!  Thanks!
Offline Kevin D
  • SE Michigan
Re: Oil drop from K0 alternator cover
« Reply #1 on: September 18, 2016, 02:45:01 PM »
Maybe it is the rubber bushing that carries the alternator wires.. If you can get a search to work, member johnie bugged that leak out and fixed it with ??? sealer. Don't worry.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Johnie
« Reply #2 on: September 18, 2016, 04:18:24 PM »
Wow Kevin you have a great memory! That was back in 2007 on the KO. Was driving me nuts. Thought it was the tranny cover as it was dripping from between the 2 covers. Narrowed to the wires that run from the stator case. Used Permatex anaerobic gasket maker. That rubber seal is in 2 halves with the wires running between them. I opened the rubber halves up and put the Permatex between the halves and then also around where it mates with the cover. Been leak free since. Good luck with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline pyropupx36
« Reply #3 on: September 18, 2016, 07:03:47 PM »
Thanks guys - will definitely have a look in that area next oil change.
 So it sounds like others have been having a problem with the web site search engine?  Everything I search for comes back with "nothing found". :-\
Offline Kevin D
  • SE Michigan
« Reply #4 on: September 18, 2016, 07:58:28 PM »
Found this tip for search:
Try this search term in Google, or in the address bar of your Chrome browser, works great. Substitute for the search terms you want, put stuff in quotes, add the + sign as desired, yadda. Works great.
site:forums.sohc4.net ignition coil
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #5 on: September 18, 2016, 08:09:41 PM »
There is no crankshaft oil seal behind the rotor, so don't worry about that; there is normally oil under both the transmission and alternator covers. Try to identify the source of the leak before taking anything apart. Clean the area of all oil residue, then dust it with talcum power or foot powder.
Offline Davez134
« Reply #6 on: September 18, 2016, 08:18:18 PM »
Exactly what Scotty said. You could have a small leak anywhere, and since the bike is always on a side stand, the oil will slowly migrate down and toward that cover. A nice clean engine is the starting point. If it is a leak from that cover, a new gasket is all that's needed, as there is always oil in there.
« Reply #7 on: September 18, 2016, 08:26:00 PM »
What Kevin and Jonnie said, I had that one too.
Offline pyropupx36
« Reply #8 on: September 18, 2016, 08:40:05 PM »
Thanks guys for all the help, and the search tip!
