Hi all, so this is my first post here after a lot of lurking. The idea of starting this project has been going around my head for many years, I'd say 5 since my beauty got bored of carrying me around and decided to smoke me up. The culprit is indeed in the top left cilinder, I knew it suffered of low pressure issues but since I didn't use the bike a lot at that time I didn't think tearing down the motor was really necessary. Well, it was, but let's talk about now.
First off, here she is
As you can see there are lots of minor issues going around, and some of them you won't even see in these pics.
The one and only issue I wanna start with is fixing the engine. I believe what caused it to fail was either the gasket (but which one?) or one/some or the bearings, but I wanna check the piston's rings too. The idea is to change them all and hope that the rest of the engine is still ok. Just for reference the bike was running (could only go in 1st or 2nd gear at very low rpms) when I put her to sleep 5 years ago, so rods and pistons should be fine. I guess.
If everything goes fine I'll proceed fixing the rest of the bike with all those "little things" that are missing or just too old.
But the real question is: I've never ever done such a thing in my life. I've been around motorbikes for a long time, I know how things works and I'm always happy when I can try to mod or tweak something and do my own maintainance to my (working) motorbikes. I also used to do all kind of nasty stuff when I was a kid to my Vespa's and other 50cc engines, but that was literally a joke compared to this one here. Is it doable for a sort of newbie like me? The problem is not much in tearing it down and changing the parts rather than in the closing it up and doing all the tweaking, registrations, tolerances, valves, shafts.....
Is there anything that I should consider before even starting the tearing down process? As for parts to be changed, I have a list and I'll need to ask you details on that since I'm not even sure which are the part numbers I need to order (mainly talking about the bearings here but will talk about that later) but is there anything I should change no matter what once I tear down a motor like this one?
All right, thanks for all the ideas and tips you may have, I hope to update this one soon.
