Author Topic: 1977 CB400F Rebuild  (Read 22354 times)
Offline 503400f
  • Uh Oh
Re: 1977 CB400F Rebuild
« Reply #25 on: October 11, 2016, 03:57:09 PM »
Time for an update.  Something finally came in the mail last week.  Figured we would just go all in and get a complete Deutsch pin and plug kit.  We have plans to do a few more things after this 400, so why not have extras?
Then the real fun began.....
You get the idea.  VERY time consuming, or i am just very slow.....probably a combination of the both.  Basically anything that had a bullet connector and or had an OEM plug got redone.  Spliced a few things so i could add plugs to things like the OEM speed / rpm gauges and other odd bits like that.  Also fixed some of the previous owners disasters from wiring in the LED blinkers / tail light.
I do not claim to be any kind of wiring professional by any means.  This is honestly the first solo job i've ever done.  Had a friend of mine help me through my scooter harness, but we didn't make it anywhere near as pretty as this one.  I'm pretty much finished with it until i get the frame back and can hang the harness back up and check lengths on a few things before i add final connectors.  Not a single butt-connectgor in the whole harness now.  Everything is either soldered and heatshrinked or pinned and plugged.
Offline marting100
« Reply #26 on: October 11, 2016, 04:53:59 PM »
Holy F$&@! You really went all-in on that one!!
Awesome job! Your full persona is coming out on that job!!
 ;D if you can make an other one and let me know when it's ready to ship,
that would make my year :)
M
Offline 503400f
  • Uh Oh
« Reply #27 on: October 11, 2016, 05:18:37 PM »
M
Man i didnt even wan't to do this one.  I absolutly hate wiring.  But the one thing I hate more than wiring is electrical issues, so sadly it had to be done.  I did not plan on going as far as i did, it just sort of snowballed into a complete refresh.  Sad part is you won't even seen 75% of the harness at all.
Offline marting100
« Reply #28 on: October 11, 2016, 05:56:04 PM »
 ;D I know what you mean, I did a full clean up with sand paper and dielectric grease
on all connectors and that was enough for me :)
Even if 20% is only visible, YOU will know you did a damm good job!
(The second one will go faster I am sure :-)
Cheers mate
M
Offline 503400f
  • Uh Oh
« Reply #29 on: October 11, 2016, 08:32:36 PM »
You are going all out and doing a beautiful job. And I don't want to panic you but...
It appears you are reusing the stock wires where possible. Essentially removing the stock bullet or pin, stripping and installing a new Deutsch pin? If so, you may find yourself coming up short (literally) on some subharnesses.  When you add the stripping from both sides of the connection, you're actually removing a fair bit.
Just saying, you might carefully plan some of those new connections and/or re-wire some that you have had to strip on both sides. I'd hate to see you short after all the time and effort to make it gorgeous.  :-\
Before i removed the harness i did check for this.  Ran into this problem on my scooter harness and had to redo a few plugs.  Most of the connectors had a fair amount of "extra" legnth to them.  Worst case scenario you're 100% right and we have to redo some connections to add some wire.  Just that much more practice i'll get with them lol.  THank you very much for the heads up, good lookin out!
Offline 503400f
  • Uh Oh
« Reply #30 on: October 13, 2016, 09:49:09 PM »
Picked up some stuff from the powder coater today!!!
Now I'm not one to plug anyone's business unless i really do have a fantastic experience....I had everything powder coated by a local place here called Color FX.  I am located in Portland, Oregon and these guys were FANTASTIC.  Quoted me a fair price for media blasting and gloss black.  Told me it would be about a week to get everything done.  Dropped it all off last Thursday, picked it up today.  When i got there he told me he found some dimples on the rear fender piece that he wasn't happy with so he decided to media blast it and redo it for me.  They went above and beyond what i expected.  They even taped off every piece of thread showing as well as plugged anywhere that had threads inside a welded on nut or something of the sort.  TGhese guys are fantastic, and i can not thank them enough.
Offline 503400f
  • Uh Oh
« Reply #31 on: October 13, 2016, 09:51:37 PM »
Dont mind all my finger prints...
Offline 503400f
  • Uh Oh
« Reply #32 on: October 13, 2016, 09:55:35 PM »
Once i went over everything i cleared the bench and began work!!  THis is where i got to before i called it a night tonight.  (Note the sexy motorcycle in the back ground)
Sure am glad we decided to go for all new hardware....looks SO good.
Dont mind that gross tan / white wire as it will be going black like the rest of the harness.
Offline marting100
« Reply #33 on: October 14, 2016, 05:23:42 AM »
Beautiful!!!
if budget allows and for maintenance free I would change the point plate for a Dyna S ignition, at the same time it will give you a brand new grey wire ;-)
Nice job mate!
M
Offline 503400f
  • Uh Oh
« Reply #34 on: October 14, 2016, 09:02:05 PM »
Looks really top notch!
Thanks!!! Appreciate the good words.
Beautiful!!!
Nice job mate!
M
I like your style.....putting that on the list!!
Offline 503400f
  • Uh Oh
« Reply #35 on: October 22, 2016, 12:42:45 AM »
Been a little while since I was able to update.  Not a ton of progress, mostly been discussing the next piece of the puzzle which is the front end.  Been in contact with Cognito over the last week ironing out some details, but i think were close to settling on the setup were looking for.  Then we just have to pay for it, which is the scary part.
As for progress on the motorcycle...Was able to get the rear fender picked up finally and installed.   This allowed to begin to finish up the rear section of the wiring.  Got the tail light and blinkers wired up and set in place.  Began to set the rest of the harness in place and check lengths and figment.  So far so good, looks like i only have to extend one section, simply because I do not like that you can see the plug from the side.  I'd like to hide it behind one of the frame tubes.  Call it OCD but I think most of the wiring should be invisible if possible.
Somehow managed to fit all the wiring through the small hole in the fender.  With the proper amount of lube and force, anything will fit anywhere.
Dropped off the front and rear wheel with the powder coater as well as the front and rear hub.  Getting them all done in gloss black.  Plan to go with polished spokes.  We have a spare front and rear complete wheel and hub set up so this fist one will just be a test run.  To see what it will look like, and to try my hand at spoking and then trueing the wheels.  Have not decided if I'll just lace my own wheel onto the cognito hub or go with one they provide.  Time will tell.
Offline 503400f
  • Uh Oh
« Reply #36 on: October 22, 2016, 06:10:16 PM »
A nitpicking observation: In an earlier picture of your front motor mounts, you have the nut on the outside of the mount. Can you not reverse those to have the head visible and the nut on the internal side? It would look more consistent and cleaner.
And be sure the ring terminals you use for grounds, hit bare metal beneath the bolts. The powder coat can create just enough shield to produce unwanted resistance and weak grounds.
Sadly the bolts go straight through the frame, so no matter what one side is going to have to have a nut.   Thanks for the tip on the grounds. I think once I figure out where I'm going to put all of them I'll just sand a very small area to be sure good contact is mde.
Offline 503400f
  • Uh Oh
« Reply #37 on: October 23, 2016, 06:55:24 AM »
Yeah, but moving the nuts to the other side was my point. You'd see the head of the bolt regularly as the exhaust will conceal the nut mostly. No matter though.
Ohhhhhhh i see where you're head is at now.  Very good point.  Thanks!  Its all in the details!!!
« Reply #38 on: October 23, 2016, 04:11:02 PM »
Uh huh.  :o
Offline marting100
« Reply #39 on: October 24, 2016, 05:34:20 AM »
Nice job!!!
M
Offline 503400f
  • Uh Oh
« Reply #40 on: October 28, 2016, 06:02:24 PM »
Got a bit more work done on the motorcycle over the last week or so.  Was able to get the second tank she had cleaned inside and sealed up.  That was quite the pain.  Once it dried for a few days i began to do work on the outside of the tank.
Once i got all the old paint off, which appeared to be original, it was time for a bit of bondo...body filler....puddy...whatever you want to call it.
I've got a couple time lapse videos that if they ever decide to upload i'll post them.  I dont pretend to be a fantastic body guy....my father is leaps and bounds better than i (he's been doing it for 30+ years).  I'll probably have him go over them and just make sure that everything is perfect before primer.  I spent most of my eight years in the paint booth rather than the body side of the shop.  I normally go there work after the filler was done....the easy parts   8)
Once I get this one in primer i'll gets started on the other tank.
Offline 503400f
  • Uh Oh
« Reply #41 on: October 28, 2016, 06:09:11 PM »
Completly unrelated to where we're at in the build so far but......
Our friend Anthoney, also known on social media as "Enginethusiast" sent this lovely gem to my girlfriend the other day.  Finally getting to some of the photos he shot a while back of her on her triumph.
This way ya'll can put a face to who will be riding the 400 once we get it finished up!!
Offline MoMo
  • Ride like you're invisible
« Reply #42 on: October 28, 2016, 06:24:56 PM »
Just got in on this thread, nice work and stunning last photo...Larry
« Reply #43 on: October 28, 2016, 07:30:37 PM »
That's great that your girlfriend rides!
« Reply #44 on: October 28, 2016, 09:07:24 PM »
Nice thread and good that MoMo has joined the thread, he has done a few 400s and 450s.  One of the brain trusts on that model on the forumfor that model(s)
Bike is looking very nice.  It will be great when it is all back together and finished up.
Never hurts to raise the bar from the initial vision, just a little harder on the budget.
David Silvers Spares , use US warehouse, is a niche supplier for original and pattern (reproduction) parts.  They have very nice quality exhausts if you decide to go that route other than ceramic coating yours.  David
Offline 503400f
  • Uh Oh
« Reply #45 on: October 29, 2016, 05:06:45 PM »
Great information.  I'll look into it!  Budget has long since gone out the window now that we've settled on the front end setup.  Going to take a little longer on the build than anticipated due to some unforeseen pet expenses....but we will get there!
Absolutley...i'll dig up some photos of her Hawk as well
Thank you!  I hear you're a brain when it comes to the 400, might have some questions eventually!!
« Reply #46 on: November 18, 2016, 12:15:36 AM »
How's the financing of the front end coming along? Tends to be a large chunk of change and with the Christmas holidays approaching many people start cutting back some spending...
Didn't know if you had an update to share.
David
Offline 503400f
  • Uh Oh
« Reply #47 on: November 30, 2016, 10:17:59 AM »
David
Thanks for the poke!
For both myself and her, bout October through the end of the year is the busiest time for our jobs.  Add in the Hollidays and it becomes a disaster!!
However we did make a slight bit of progress.  Got a wheel laced up and looking relatively pretty.  Just need to find some time to go pick up a stand and try my hand at trueing the wheel.
From everything i can see and read, i've got it done right.  She's got a spare wheel so it was pretty easy to copy it.
Offline spuds
« Reply #48 on: December 04, 2016, 06:09:30 PM »
Um, wow.
New around here, and slowly going through some builds etc.  Will definitely be following this one.   Anxious to see the updates.   Nice work!
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #49 on: December 04, 2016, 06:36:13 PM »
        Hope you all will excuse me, but I am going through this build, along with a few others, and trying to catch up and I have to say that this wiring redo, is quite an undertaking that looks like it should cut down some issues that could pop up (like someone said though, hope the wiring harness doesn't come up short, though I imagine you will work that out, as I got from your response on the subject. I'm still learning and reading. ;-)
Member # 1969
