Did you verify cam timing??
50 RWHP is less than a stock 750? My 836 with a stock un-ported K1 head and Weber carbs with 30mm chokes put out 70 RWHP on the dyno, and I believe with a ported head would be close to 80. Can you post the dyno printout?
My 836 with ported head, 34mm in valves same cam and carbs as you gave 80rwhp.Jets: Main 135 (150), pilot 30 (27.5), needles 4:th (as std), fuel screws 1.5 turns out. KN pod filters and rather open 4-1. main 150 might be for vel stacksChanged main to 130 with 4-4 without diffusers. This is too lean.Ignition might be retarded which make engine powerless. I heard pinging from low so I retarded ignition and lost the pinging AND power. Too lean carbs got richer mixture (pilot) and correct ignition woke up the power.
I'm running 137.5-142 mains, RS34's, 1080 kit, hi compression, 327 cam ,ported head, etc, @ least 110hp. You are too rich my .02, but you gotta check all the other things mentioned, G'luck, Bill
"leak down" ? I have done a compressiontest a it was between 9 and 10
Thanks Mike the tool i used for messuring is not a precise tool, just giving me a compression reading on each cylinder. I can see this leak down tool is very helpful.I'm almost sure now, my timing is not correct, almost 10 degree off on a quick messure. Have to work on that Sent from my iPhone using Tapatalk
Where are you measuring the 10 degree error, at the cam? There are 34 teeth on the cam sprocket, so 10.588 degrees per tooth.Does your compression tester read in Bar? One Bar equals about 14.5 PSI, so 10 Bar is 145 PSI. Cam timing will also affect cranking compression, so verify that first.
