Author Topic: 76 CB750 Wont Idle  (Read 819 times)
Offline tylerdb
76 CB750 Wont Idle
« on: October 10, 2016, 04:10:54 PM »
Bike starts and runs with both the choke on and off but wont idle.
With stay running with the throttle barely cracked open.
Bought the bike from a friend and the carbs were cleaned and bench synced before i bought it but were left without an air filter on them for the last few months. Also just added a 4-1 exhaust.
Guessing i should go up a pilot jet size?
Saskatchewan, Canada
Re: 76 CB750 Wont Idle
« Reply #1 on: October 10, 2016, 04:59:11 PM »
 Have you tried increasing the idle with the idle adjustment knob under the carb bank ?
Offline tylerdb
« Reply #2 on: October 10, 2016, 06:40:15 PM »
Wow do i feel dumb, i jumped to the conclusions that the jetting wasn't correct/dirty carbs right away.
Increased the idle and it idles fine. It dies when i crack the throttle but is fine when i roll on the throttle.
Assuming this is a lean pilot circuit?
« Reply #3 on: October 11, 2016, 06:28:56 AM »
Did you get your air filter and air box back on it?
Its an important piece of the air/fuel equation.  :-\
Offline tylerdb
« Reply #4 on: October 11, 2016, 08:01:27 AM »
Yes stock air box w/ new filter. The air box has had holes drilled into it by the PO.
4 into 1 exhaust with baffle.
« Reply #5 on: October 11, 2016, 08:11:45 AM »
Turn the idle set screw in to keep it from dying after you take the choke off.
