1973 CL350
First, I ordered the wrong cable by mistake. Got the new one in and went to make the static clutch cable adjustment only to find the lock nut hopelessly frozen on the stud.
I've tried penetrating oil, heat, tapping it with a hammer....even using Vice Grips on the screwdriver handle. I disassembled it as much as I could from the inside of the cover but couldn't back it out.
Before I order a whole new sprocket cover, any tricks to separate the death grip?
The bad thing is, I was just at Barber and could have filled up a box with sprocket covers for $5 each!! Doh!
As you can see, the slot is already starting to get boogered up. I can't get the threaded portion and the lock nut to separate. I removed the piece from the inside, but it still just spins as one unit. I'm not sure how to remove it from the cover without getting the lock nut off.
