Author Topic: The Amalgam: honda past meets present, take 2! or 3?  (Read 42153 times)
Offline jag767
Re: The Amalgam: honda past meets present, take 2! or 3?
« Reply #150 on: June 22, 2017, 07:41:04 PM »
Love the look....  Yes, clearance is an issue, but all of those Harley bagger guys scrape the ground.... why can't you??!!
Lol. I'm going to rock the hardest suspension you've ever seen. I actually have a solution, it's just a lot of time and money. If I make a new header that's half the puzzle, and the 2nd part is a custom oil pan. I can easily pick up an additional 2 inches of ground clearance.
Online grcamna2
« Reply #151 on: June 22, 2017, 07:44:19 PM »
subscribed
75' CB400F/'bunch o' parts'
« Reply #152 on: June 22, 2017, 10:24:32 PM »
I hope you are young and not real tall because those rearsets are going to fold you up pretty good.  I prefer my pegs closer to the swingarm pivot...
But, I have neck and low back issues and cannot ride in a sportbike position.
David
Offline jag767
« Reply #153 on: June 22, 2017, 11:04:44 PM »
David
Hey I'll have you know I'm every inch of 5' 6" lol. AND my legs are short for someone of my height. Back like that it opens up my hips nice and it's just really comfortable. Being 31 helps too!  ;D
Offline jag767
« Reply #154 on: June 23, 2017, 08:30:09 AM »
One more
« Reply #155 on: June 23, 2017, 11:55:08 AM »
The radiator and brake rearset will have their issues to face.  But you will have a unique bike that should be lots of fun.  The drums can be arced and relined with better friction material if you need better stopping power. Vintage Brake is great for that.
David
« Reply #156 on: June 23, 2017, 01:15:27 PM »
Just install a spark plate and it'll be good.  I'm sure you will sort out the clearance issue.  The bike is unique and looking good.
Offline jag767
« Reply #157 on: June 23, 2017, 02:34:57 PM »
Thanks! I came up with a dolution its just a pain. Make a new exhaust and new oil pan problem solved.
« Reply #158 on: June 23, 2017, 02:39:04 PM »
Jag,
I may have missed this but are you going to use the "stock" EFI and modify the tank to accept a fuel pump or are you going to retrofit carburetors?
Offline jag767
« Reply #159 on: June 23, 2017, 04:12:08 PM »
Jag,
Keeing the efi and refitting the fuel pump
« Reply #160 on: June 23, 2017, 04:19:07 PM »
Jag,
Makes sense. That's a little bit of tank surgery but nothing too nuts.
Offline jag767
« Reply #161 on: June 23, 2017, 04:37:01 PM »
Jag,
I cheated a little, i picked up a dented tank with the flange i need, so cut and paste? Lol
« Reply #162 on: June 23, 2017, 04:48:50 PM »
Jag,
Very smart solution.
Offline jag767
« Reply #163 on: June 23, 2017, 04:51:17 PM »
Jag,
Haha thanks, i did the downtubes the same way
Offline jag767
« Reply #164 on: June 24, 2017, 04:50:15 AM »
The plan is to drop the exhaust and pan today. My buddy is gonna take it to work to scan, and he is gonna cnc a new flange to build a pan onto. Im also going to have him do a flange for the throttle bodies to build the intake off of. I also ordered a 7mm offset 520 sprocket to finish up the powertrain.
As far as exhaust, i want to do something different, might try to keep that metal shield and have the exhaust exit through it somehow. The cat is going buh bye,  maybe just a small can behind the shield then tubing from the back of it to exit the shield. Just thinking out loud.
Offline jag767
« Reply #165 on: June 24, 2017, 12:46:44 PM »
Long story short, a friend is making me a billet aluminum oil pan 2 inches deep, so I will have 4.5 inches ground clearance. Here it is with the oil pan and exhaust off.
« Reply #166 on: June 26, 2017, 01:49:34 PM »
jag,
I noticed from the first post that you were hoping to get 60 hp out of the CBR500 engine.  That motor in stock form makes about 47 hp and 32 ft lbs of torque.  Are you doing some tuning work to the engine to extract the additional 13 hp?
« Reply #167 on: June 26, 2017, 03:33:45 PM »
jag,
I remember hearing that the CB500F/CB500X/CBR500R motors are all limited to 47 hp to qualify for riders with stepped licensing in Europe and Asia.  Supposedly, you can use a Power Commander to unlock 53 hp but this will void your warranty (not that you appear to have one). You can extract another .6-1 hp with exhaust.  I don't know how much more you can get.  There is no known big bore kit that will not cause the ECU to go catty wampus.
« Reply #168 on: June 26, 2017, 03:37:55 PM »
My buddy got approx. 67-68 horsepower at the rear wheel from a 1990 Kawasaki EX500, Bored to 600cc with Engine Dynamics kit, Webcam 245 cams, Barnett clutch, heavyweight springs - mated to a CB550 frame.
The Honda should probably make more power if it was not specifically designed not to make over 47 hp.
« Reply #169 on: June 26, 2017, 05:16:34 PM »
In retrospect, he probably could have used a Ninja 650 twin with 71 hp/47 ft lbs stock, but I'm not sure how easily it would slot in. The EX500 motor fit easily.
The 650 motors are cheap and go for about $700.
Offline jag767
« Reply #170 on: June 26, 2017, 05:51:50 PM »
I figure exhaust with no cat, better intake, ported, cam and tune, 60 shouldnt be difficult. If i want to make sure to get there ill mill the the head to raise compression and adjust the pistons if necessary. I think thats more than enough to get over that number though. Theres one guy with something like 57 to the wheel with less that that.
« Reply #171 on: June 26, 2017, 06:07:42 PM »
Sounds like a little bit of money and someone who knows how to tune a Power Commander.  I'm interested to see what you get out of it.
Offline jag767
« Reply #172 on: June 26, 2017, 08:00:12 PM »
My machinist/tuner owes me a favor for some paint work, which is why come to think of it If anything I will hold off on the cams and do the rest. I f I wanted to be a pain I'd ask him to lighten the crank lol!
« Reply #173 on: June 27, 2017, 12:05:16 AM »
The license classes in Europe and many other countries is based upon kw and hp, the A2 license is limited to 46 hp and thus the limitations on the motor...
Many today do it with electronics.  Most do not go by the hp numbers these days in Europe...
Offline jag767
« Reply #174 on: June 27, 2017, 12:56:32 AM »
If someone were to go hog wild with this motor, I'd wager it could get to 70-75 crank hp before reliability goes out the window. I don't plan on pushing the envelope too far, since this motor in stock form is made to last, and I want to keep that. Just a little coaxing is all I'm looking for. That combined with how little it weighs..... well it'll do what I want it to  ;D. I keep saying I'm building this to show more than ride, but if it rides as good as I'm hoping I may have to build one to ride and a 2nd to show lol.
