Author Topic: question about the regulator/rectifier  (Read 783 times)
Offline hairpincorners
« on: October 20, 2016, 05:31:02 PM »
hello everyone. new here. hopefully someone can help me out.
i have a 1978 cb750 SOHC with a rick's regulator/rectifier. bike was overcharging. tested the field coil and stator as well and they checked out good. so i put my stock voltage regulator back on and it's charging properly. my question is, is it safe to use the rick's combined r/r as only a rectifier and use the stock voltage regulator?
TIA
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: question about the regulator/rectifier
« Reply #1 on: October 21, 2016, 01:51:17 AM »
+1 for oregon motorcycle parts - it just works.
Offline philgresty
« Reply #2 on: October 21, 2016, 04:13:18 AM »
i run an oregon regulator and oem rectifier, cant fault it atall
Offline Bodi
« Reply #3 on: October 21, 2016, 06:53:12 PM »
Yes. No problem. Just connect the 3 yellows, red to the battery, and ground. Tie the rest out of the way. The two reg and rec are separate circuits sharing the case.
  • Holy Cow! I'm a
« Reply #4 on: October 21, 2016, 07:29:54 PM »
I went went the separate units.  Fit in factory locations with factory connections.
